Work density / heat density question
The discussion focuses on a piston-cylinder device containing R-134a at an initial pressure of 400 kPa and a temperature of 40 degrees Celsius. The final state temperature, after adding heat while maintaining constant pressure and achieving a specific volume of 0.07 m³/kg, is determined to be 85.5 degrees Celsius through linear interpolation using thermodynamic tables. The boundary work is calculated using the formula Wb = P(V2 - V1), while the heat density is derived from the enthalpy change Q,in = H2 - H1. The discussion seeks clarification on the physical meanings of work and heat density.
  • Understanding of thermodynamic properties of refrigerants, specifically R-134a.
  • Familiarity with thermodynamic tables, particularly table A-13 for superheated gases.
  • Knowledge of boundary work calculations in thermodynamic processes.
  • Ability to perform linear interpolation for thermodynamic properties.
  • Study the thermodynamic properties of R-134a in detail, focusing on superheated states.
  • Learn how to perform linear interpolation using thermodynamic tables.
  • Research the concept of boundary work and its applications in thermodynamic cycles.
  • Explore the definitions and calculations of work density and heat density in thermodynamic processes.
Thermodynamics students, mechanical engineers, and professionals involved in HVAC systems or refrigeration technology will benefit from this discussion.
eurekameh
A piston-cylinder device holds R-134a at an initial pressure of 400 kPa and a temperature of 40 degrees Celsius. Heat is added until the specific volume is v = 0.07 m^3/kg while the pressure is held constant.
a. Determine the temperature of the final state.
Because the pressure is 0.4 MPa and the specific volume v = 0.07 m^3/kg and because it is a superheated gas, I used table A-13 of the thermodynamic tables and found that that temperature is between 80 - 90 degrees Celsius. Using linear interpolation, I get 85.5 degrees Celsius.
b. Determine the work density associated with this process.
c. Using enthalpy determine the heat density required for this process.
d. Determine the heat density required for this process by explicitly
using boundary work.
For b, I found the boundary work Wb = integral(P dV) = P(V2 - V1) and realized that I only have the specific volume at both states, but not the volume. For c, I did Q,in = H2 - H1, where H is the enthalpy. Then I realized that I only have the specific enthalpy h. How do I go about solving this problem? Also, can anyone explain what the work and heat density specifically and physically is?
Anyone?
