Python Help: Convert Celsius to Fahrenheit
  • Context: Python
  • Thread starter Thread starter TromboneNerd
    Python
The discussion revolves around a Python programming assignment that involves converting temperatures from Celsius to Fahrenheit. Participants are addressing issues related to user input handling and conditional statements in the code, particularly focusing on how to stop the conversion process when the user inputs 0.
  • Homework-related
  • One participant describes their issue with the code, noting that entering 0 does not terminate the loop as intended, and they seek assistance with their if statement.
  • Another participant points out that the method Celsius.rstrip() returns a string, while int(Celsius.rstrip()) converts it to an integer.
  • A third participant suggests a modification to the if statement, recommending that the comparison should check if Celsius.rstrip() equals "0" instead of 0.
  • One participant expresses a concern about posting in the wrong forum and requests a moderator to delete the thread.
There is no consensus on the solution to the problem, as participants are providing different suggestions and clarifications without agreeing on a definitive fix.
The discussion highlights potential misunderstandings regarding data types in Python, specifically the handling of strings and integers, but does not resolve the underlying issue in the code.
TromboneNerd
Im having trouble with a basic python assignment in one of my classes. Its supposed to ask the user for temperatures in Celsius and convert them to Fahrenheit, which it does fine. The problem is that its also supposed stop asking the user if he gives it 0, which means the end of the list of numbers. My program converts fine, but upon entering 0 it just gives me 32, which means something is wrong with my if statement and its just converting 0 like a normal number. Any help? here is my code.
count = 1
converted = False
while (converted == False):
Celsius = raw_input("Temperature number " + str(count) + " to be converted?: ")
if (Celsius.rstrip() == 0):
converted = True​
Celsius = int(Celsius.rstrip()) * 1.8 + 32
print (Celsius)
count = count + 1​
Technology news on Phys.org
I also just realized this is in the wrong forum. If a mod would kindly delete it ill just re-post in the correct forum. #apologies
note that Celsius.rstrip() is a string
int(Celsius.rstrip()) is an integer
I took your code and put it in [ code ] tags.
Code:
count = 1
converted = False
while(converted == False):
        converted = True
    print(Celsius)
    count = count + 1
You may want to refactor a bit, as there are some things you can do to make the code more "Pythonic". For your original question, try
Code:
if Celsius.rstrip() == "0":
as your test.
  • · Replies 28 ·
