Understanding Tangents in Analytic Geometry
The discussion centers on the concept of tangents in analytic geometry, specifically the relationship between slope and the tangent of the angle of inclination (θ). The slope is defined as m = -1/2, leading to the calculation of θ using the inverse tangent function: θ = tan^-1(-1/2) = 153°26'. The explanation clarifies that the tangent function represents the ratio of the opposite side to the adjacent side in a right triangle, and in the context of a curve, the tangent line touches the curve at a single point. This understanding is crucial for interpreting slopes and angles in analytic geometry.
  • Understanding of basic trigonometric functions, particularly tangent and inverse tangent.
  • Familiarity with the concept of slope in coordinate geometry.
  • Knowledge of right triangles and their properties.
  • Basic principles of analytic geometry, including curves and tangent lines.
  • Study the properties of tangent lines in analytic geometry.
  • Learn about the relationship between slopes and angles in coordinate systems.
  • Explore trigonometric identities and their applications in geometry.
  • Practice problems involving the calculation of angles using the inverse tangent function.
Students of mathematics, particularly those studying analytic geometry and trigonometry, as well as educators seeking to clarify these concepts for their students.
ObsoleteBacon
Okay so I am reading a book on analytic geometry because my algebra class is starting to really bore me, and I ran across this:
slope = m = -1/2 (easy enouph)
but then it states "since the slope is the tangent of the angle of inclination θ, we have: tan θ = -1/2
okay so I guess my first question is: What is a tangent in analytic geometry?
continuing with my story: the very next thing it gives my is the angle of inclination
So for this it goes: θ = tan^-1 (-1/2) = 153°26'.
What the heck? Can someone explain this problem above in greater detail. I know that tan^-1 is the inverse of tan but without understanding what tangent actually is that doesn't help me much. Also, how do you calculate this to get the answer? I have looked at a ton of online sources but can't seem to find any answers to my questions.
Have you done trigonometry?
I don't understand if your problem is with the tangent -trigonometric function- or the tangent -the line on a graph. I'll try explaining both.
The latter:
take a curve. Fix one point on it, let it be P. Then, fix another point, let's say S. Draw the straight line connecting P to S (called secant). Then, move S until it overlaps P. The line you drew will move along with S. When S overlaps P, the line (now called tangent) will touch the curve in one and only point (P) - at least, the intersection will be one looking near P, but it can intersect the curve in other points.
http://en.wikipedia.org/wiki/Tangent" on wiki.
As regards the trigonometric function, in a right triangle, the tangent of an angle (not the right angle, however) is the ratio between the opposite and the adjacent sides.
So, when it says that the slope is the tangent of the angle of inclination, it means that is the tangent of the angle of inclination of the tangent on the curve. The slope is the tangent of θ because the evaluation of the slope ([itex]\frac{y_2-y_1}{x_2-x_1}[/itex]) can be seen as the ratio between the two catheti of the triangle made by the x axis, the tangent and the height of the tangent in the point you are considering.
Sorry for my bad english, but I've never studied geometry in english, so I don't know the specific language :D Hope you understand and that it is ok!
Thank you for the answer it helped a lot. I wasnt sure whether it was telling me to use the first or second way, but now i know its the trigonometric way (i think i spelled that right)
  • · Replies 30 ·
  • · Replies 21 ·
  • · Replies 59 ·
232K
