Currents in Parallel Homework: Determine Magnitude of Current
  • Thread starter Thread starter j.m.g.
    Currents Parallel
The problem involves determining the magnitude of the current in a lower wire that is parallel to a wire carrying a known current of 48 A. The setup includes a magnetic suspension scenario where the distance between the two wires is 15 cm, and the diameter of the lower wire is given as 2.8 mm. The participants are exploring the forces involved in keeping the lower wire suspended and the relevant equations that govern the situation.
  • Participants discuss the use of the equation for force per unit length in magnetic fields and question how to derive the necessary force to balance the electromagnetic force. There are attempts to relate the problem to gravitational force and mass, as well as inquiries about the implications of switching off the current in the upper wire.
The discussion is ongoing, with participants sharing their attempts and expressing uncertainty about specific calculations and concepts. Some guidance has been offered regarding the relationship between mass, area, and gravitational force, but there is no clear consensus on the correct approach or solution yet.
Participants note the absence of explicit force values and the need to derive them from the given parameters. There is also a mention of potential confusion regarding the cross-sectional area calculation due to misinterpretation of the wire's dimensions.
j.m.g.
A long horizontal wire carries a current of 48 A. A second wire, made of 2.8 mm diameter copper wire and parallel to the first, is kept in suspension magnetically 15 cm. Determine the magnitude of the current in the lower wire.
I know that F/L=(μ0*I1*I2)/(2∏r).
By using that equation I am not sure how to solve for F/L. Otherwise I know μ0=4∏*10^-7, I1=48A and r=0.15 m. I also know that I am solving for I2. My main problem is the left side of the equation.
What force on the wire is balancing the one due to the current such that the wire is suspended (and not flying away!).
I'm not sure. I literally gave you everything I know from the problem. I do know that somehow you need to use F=ma to get the other side to work and F/L ends up being something like ALp, but I am not sure how that works.
To support gneill's question. What would happen if the 48A current was switched off? and why?
Putting aside the given problem for a moment, if you wanted to suspend a wire or anything else for that matter, in the air, what force do you need to oppose?
You need an equal and opposite force. When looking at the problem I know that the two wires share this equal and opposite force.
Suppose I 'suspend' a ball by holding it with my hand a few centimeters above the ground. I release the ball. What happens and why?
The ball drops due to the force of gravity.
Bingo! The wire is being pushed up (or held up) by the electromagnetic force due to the currents running through them. But what force is it being held against? How might you calculate it? (You may need to look up some additional information based upon the information given in the problem) :wink:
I am not sure I know how to figure out that calculation. That has been my main problem with this question.
What information are you given about the object being held up?
I have the question I put in the first box and a diagram that shows the current of the top wire is 48A the distance between the two wires is 0.15 m to the unknown wire. I am to find the magnitude of the lower wire. My professor went over this question in class as did my AI and I just cannot grasp the problem for some reason. I understand pretty much everything but how to work the left side of the equation I posted in the first box.
You need to figure out the what force (per unit length) that the electromagnetic force needs to balance. Once you have that you can use your equation to determine the required current.
Since we are not given a force it was my understanding that somehow we need to plug in B (the magnetic field) times the current times the length. That equals mass times gravity. I have attempted this problem many times, but for some reason I cannot come up with the correct answer. Is there something I am doing wrong?
Post your calculation so that we can see your attempt.
I used ALP=(μ0*I1*I2)/(2∏r). In my equation I put in (1.25∏*10^-7)(8.96*10^3)(9.8)=((4∏*10^-7)(48)I2)/(2∏*0.15). I then solved for I2.
What's the 1.25∏*10^-7 number on the left?
That was me attempting to figure out A and L. I do think that is my main problem with this equation. I think the rest of my information is correct.
Mass = ρ*Area*Length
So that
Mass/Length = ρ*Area
That is, the mass per unit length is the density multiplied by the cross sectional area.
Okay. So I used ∏r^2 (∏(2.8*10^-3)^2) for the cross sectional area. I multiplied it by p (8.96*10^3) and by gravity (9.8). I still did not get the correct answer for I2. What am I doing wrong? Is my cross sectional area of a cylinder incorrect?
Isn't 2.8mm the diameter and not the radius?
You're right, I can't believe I messed that up! Thanks so much for all of your help!
  • · Replies 24 ·
