Two Phase - Three Phase - Whats the scoop?
  • Thread starter Thread starter DaVinci
    Phase Three phase
The discussion revolves around the concepts of two-phase and three-phase electrical systems, particularly in the context of household electricity and their applications. Participants explore the definitions, historical context, and practical implications of these systems, including their use in various electrical applications.
  • Some participants express confusion about the existence and definitions of two-phase and three-phase systems, with one participant questioning the necessity of multiple phases.
  • One participant asserts that there is no such thing as two-phase power in the context of AC power, suggesting it is a misinterpretation.
  • Another participant counters that two-phase AC does exist, particularly in applications like servo motors, but is not used for general AC power distribution.
  • A historical perspective is provided, noting that Nikola Tesla utilized two-phase systems, which were once common in the U.S. but have since fallen out of use in favor of three-phase systems.
  • Discussion includes the technical details of how three-phase systems operate, including their efficiency and the reduction of inductive line losses.
  • Clarifications are made regarding the nature of domestic electricity in the U.S., with some participants emphasizing that 240V is derived from a single-phase system with a center tap, rather than two distinct phases.
  • There is a mention of potential confusion arising from the terminology used to describe phases and voltages in electrical systems.
Participants express differing views on the existence and definitions of two-phase systems, with some asserting its validity in specific contexts while others argue against its relevance in general AC power discussions. The discussion remains unresolved regarding the terminology and understanding of phase systems.
There are limitations in the discussion regarding the assumptions made about phase definitions and the implications of terminology used, which may lead to misunderstandings about the nature of electrical systems.
DaVinci
I am a little embarassed asking this, as I was an aircraft electrician at one time, but have since forgotten the answer. :bugeye:
When dealing with house electricity, you commonly hear the terms two phase and three phase. Now I understand this to be that the 'waves' are 'out of phase' by a certain degree.
But why do we have them? Why multiple phases? Simple so we can tie two together to get 220V for certain appliances? Is it simply a matter of convience that we can bring in more on the same line?
There really is no such thing as two phase. Have a look at the earthing alternatives thread and you will find some good info.
This is actually the info I was looking for...
http://ths.gardenweb.com/forums/load/wiring/msg112302526261.html
I know he was corrected, but in that thread one guy is bleating on about 2 phase systems. Ignore him!
There IS such a thing as two-phase AC. It's used with servo motors, where the phase angle determines position. But it's not used for AC power.
... In Germany and Switzerland, where three-phase power was originated and developed, it is known as Drehstrom, "rotating current" for this property of constant power. Ordinary AC is called Wechselstrom, or "change current." Nikola Tesla, the discoverer of polyphase currents and inventor of the induction motor, employed two-phase current, where the phase difference is 90°. This also can be used to create a rotating magnetic field, and is more efficient than single-phase, but is not quite as advantageous as three-phase. Two-phase power was once rather common in the United States, where Tesla was important in the introduction of AC, but has now gone completely out of use.
Two-phase can be supplied over three wires, but there is no true neutral, since the phases are not symmetrical. However, it is always easy to double the number of phases in a transformer secondary by making two secondary windings and connecting them in opposing phases. Four-phase does have a neutral, like three-phase, but requires four wires. In fact, three-phase is more economical than any other number of phases. For applications like rectifiers and synchronous converters where DC is produced, it is most efficient to use six-phase AC input, which is easily produced from three-phase in a transformer. [continued]
http://www.du.edu/~jcalvert/tech/threeph.htm
Domestic or house current in US is single phase (line-to-neutral) 120 V, 60 Hz.
IIRC, 240 volt comes from 2 line to neutral phases.
T&D systems use 3 phase, each 120° out of phase to the others. This also helps to reduce inductive line losses.
i was the one that started the "Earthing alternatives" thread and i now realize that what peope are referring to as 3 phase and 2 phase (which i was referring to myself), is the misuse of a term as i understood from Averagesupernova. What they are referring to as the different phases is just the difference in the voltage (and current) but as i learned it is much more than that.
Actually domestic 240 volt is single phase with a center tap typically grounded and identified as neutral.
The confusion stems from the assumption that 3 live lines equals 3 phases, so 2 live lines are 2 phases. Not so.
If we label the 3 lines A, B, and C, we create the phase relationships of AB, AC, and BC. If one fuse blows, say line B, we lose AB *and* BC, so we're down to single phase of AC only.
  • · Replies 17 ·
  • · Replies 60 ·
18K
  • · Replies 83 ·
10K
