Why Multiply Proportional Quantities to Find the Constant?
This discussion clarifies the relationship between proportional quantities in mathematical expressions. When a ∝ b and a ∝ c, the correct formulation is a = k₃bc, where k₃ is a constant of proportionality. The confusion arises when attempting to combine constants from multiple proportional relationships; the correct approach does not involve multiplying the constants directly. Instead, the relationship a = k₄bcd holds when considering multiple variables, leading to a misunderstanding of the powers of a in the context of proportionality.
  • Understanding of proportional relationships in mathematics
  • Familiarity with constants of proportionality
  • Basic algebraic manipulation skills
  • Knowledge of how to derive relationships from multiple equations
  • Study the concept of direct and inverse proportionality in mathematics
  • Learn about the properties of constants in algebraic equations
  • Explore the implications of combining multiple proportional relationships
  • Investigate the derivation of equations from proportional relationships
Students, educators, and anyone interested in understanding mathematical relationships and proportionality in equations.
autodidude
If a ∝ b and a ∝ c, why do you multiply b and c together to find the constant?
I also noticed something, but am not sure of the reason why. If you find the constants individually for each expression and combine them all, you get a the the power of the number of expressions
e.g.
a ∝ b
a ∝ c
a ∝ d
So the individual constants would be say, k1, k2 and k3 respectively. If you then multiply it all together
a ∝ (k1b)(k2c)(k3d)
You get a^3
If there're expressions, then a^4 etc. All of the numbers I've tried so far have yielded the result but I'm not sure why that's happening
Thanks
Mathematics news on Phys.org
Your question is very confusing.
You don't. If [itex]a\propto b[/itex] and [itex]a \propto c[/itex], then that tells you that [itex]a = k_3 bc[/itex], where k3 is some constant of proportionality. This is because:
Given both [itex]a = k_1(c)b[/itex], where k1(c) is a proportionality factor that you know depends on c, and [itex]a = k_2(b)c[/itex], where k2(b) is a proportionality factor that depends on b, you can divide the two equations to get
[tex]1 = \frac{k_1(c)b}{k_2(b)c},[/tex]
or
[tex]\frac{k_1(c)}{c} = \frac{k_2(b)}{b}.[/tex]
However, by assumption k1 depends only on c and k2 depends only on b, so the only way this relation can hold is if both sides are equal to the same constant, say k3. It follows then that [itex]a = k_3 bc[/itex].
e.g.
a ∝ b
a ∝ c
a ∝ d
a ∝ (k1b)(k2c)(k3d)
You get a^3
Thanks
I'm not sure what you're talking about here. If a is proportional to all those variables, then [itex]a = k_4bcd[/itex], by similar logic to what I did above. I'm not sure where these powers of a comes from.
  • · Replies 33 ·
  • · Replies 38 ·
