| New Reply |
Solid volume rotation around y-axis |
Share Thread | Thread Tools |
| Oct11-11, 03:08 AM | #1 |
We have to trace a pumpkin on graph paper and then find it volumne when rotated around the y-axis. Upon doing so we have 2 pieces we can do. One is a semi circle and the other just a rectangle. Refer to this image: ![]() Where we can see the diameter of the circle is 13.5 and the full width of the shape is 9. 2. Relevant equations (x-h)^2 + (y-k)^2 = r^2 v = integral from a to b pi r^2 times thickness (dx or dy) 3. The attempt at a solution Know the diameter is 13.5, we know the radium is (13.5 / 2) or 6.75. Using that we can pinpoint the origin of the semi-circle to (2.25,6.75), where 2.25 is the width of the whole shape (9) minus the radius (6.75). We use the formula of a circle with center h,k: (x-h)^2 + (y-k)^2 = r^2 Thus: (x-2.25)^2 + (y-6.75)^2 = (6.75)^2. We know to be with respect to y there we solve for x: x = sqrt( (6.75)^2 - (y-6.75)^2) + 2.25 Now we get into rotating around the y-axis. The semi-circle is shifted 2.25 from the y-axis so you add 2.25 to the equation, giving you a radius of sqrt( (6.75)^2 - (y-6.75)^2) + 4.5 thus: v= pi * integral from 0 to 13.5 (sqrt( (6.75)^2 - (y-6.75)^2) + 4.5)^2 dy which is about 1327.56 pi. Finally just add to that the retangle rotated around y-axis which is radium 2.25: v = pi * integral from 0 to 13.5 (2.25)^2 dy which is about 68.3438 pi. Answer being about 1395.9 pi. I know this is wrong because if I just do a large rectangle of width 9 and rotate it around I get v = pi * intefral from 0 to 13.5 (9)^2 dy or 1093.5 pi. This should be larger that my previous answer, and it's not. |
| Oct11-11, 06:20 AM | #2 |
And you need not find the volume for the rotation of rectangle separately because as per the formula its the volume generated when the AREA UNDER THE CURVE x = sqrt( (6.75)^2 - (y-6.75)^2) + 2.25 from 0 to 13.5 is rotated |
| Oct11-11, 12:36 PM | #3 |
It's my understanding that because the rectangle create a 2.25 by 13.5 gap from the y-axis that when you rotate it around the y-axis it will have a center out hole, thats why you need to add the rectangle to fill that piece.
Also I add 2.25 to the equation because that's the distance from the y-axis. I believe part of my issue is that I need the semi circle to have a maximum all the way to the right, basically the top of a circle but rotated 90 degrees clockwise. I thought switching x and y around would do that but I am unsure now. |
| Oct11-11, 01:19 PM | #4 |
Basically what you do is find the volume of the "pumpkin" and subtract the rectange from it.
| Oct11-11, 01:19 PM | #5 |
The volume of the rectange
| Oct11-11, 01:20 PM | #6 |
Why would you subtract the rectangle from it? It's apart of the pumpkin.
| Oct11-11, 01:44 PM | #7 |
Mentor
You're rotating about the y-axis (x=0) not about x = -2.25.
Look at the expression, sqrt( (6.75)^2 - (y-6.75)^2) + 2.25 for y = 6.75. you will get 9, which agrees with you diagram. as the radius of the largest horizontal cross-section. |
| Oct11-11, 03:20 PM | #8 |
it would be: int((sqrt(45.5625-(y-6.75)^2)+2.25)^2, y = 0 .. 13.5) and thus the answer is 800, which makes it fit. Thanks for the explanation. |
| New Reply |
| Thread Tools | |
Similar Threads for: Solid volume rotation around y-axis
| Volume of a solid between 2 functions revolved about the x-axis | Calculus & Beyond Homework | 1 | ||
| Volume, rotation around axis | General Math | 1 | ||
| How to set up a volume of solid of revolution about a line other than the x axis | Calculus | 2 | ||
| Volume of solid revolving about y-axis | Calculus & Beyond Homework | 2 | ||
| Finding Volume of Solid Rotated X-Axis | Calculus | 1 | ||
