Geometry Problem: Finding the Sum of Perpendiculars in an Equilateral Triangle
  • Thread starter Thread starter sankalpmittal
    Geometry
The problem involves an equilateral triangle with a given side length and a point inside the triangle. The task is to find the sum of the perpendicular distances from this point to the sides of the triangle. The context is geometric reasoning related to properties of triangles and area calculations.
  • Participants discuss using the area of the triangle in relation to the perpendiculars and the triangle's side length. Some express confusion regarding the notation and reasoning used in the problem setup. Others suggest using similarity of triangles as a potential approach, although it is noted to be complicated.
There has been some productive exploration of the area method to relate the perpendiculars to the triangle's area. Participants have shared equations derived from their reasoning, and there is an ongoing dialogue about the relevance of the given distance from the point to one side of the triangle.
Some participants question the necessity of the given length of one of the perpendiculars, suggesting it may not be needed for solving the problem. There is also a mention of potential confusion caused by the problem's setup.
sankalpmittal
Let ABC be an equilateral triangle with side 10 cm and let P be a point inside the triangle at a distance of 2 cm from the side AB. Given --> AB = BC = CA = 10cm and PD = 2 cm. If PD, PE, PF are the perpendiculars to the three sides, find out the sum, PD + PE + PF.
Here is the image : http://postimage.org/image/1lt6hjgw4/
I am not sure which equation is most relevant being a geometry question.
I tried using similarity of triangles and Pythagoras theorem and trigonometry. I tried messing up all these things but failed to get the solution.
Try to express to area of the triangle with PE, PD and PF and with the side of the equilateral triangle.
ehild
ehild
This is how I worked : http://postimage.org/image/1wf8ya2sk/
Am I correct ?
I found these equations :
x + 2*sqrt(3)/3 = r+y
x+y+r = 10
x-r-y= - 2*sqrt(3)/3
Am I Correct ?
I can not follow you. Why did you note by x both the upper and lower parts on the left-hand side of the triangle? The problem can be certainly solved by using similar triangles, but it would be complicated.
Why do you not try the area method? What are the areas of the coloured triangles in terms of PD, PE, PF? What is the area of the big triangle?
ehild
ehild
OK , I get it .
Area of green Δ = 1/2 x 10 x PE = 5PE
Area of yellow Δ = 1/2 x 10 x PF = 5PF
Area of light blue Δ = 1/2 x 10 x PD = 5PD
Area of big Δ = sqrt(3)/4 x 100 = 25 sqrt(3)
5(PE + PF + PD) = 25 sqrt(3)
PE + PF + PD = 8.66025 cm approx.
Now , I can't understand why they gave me the length of PD. There was no need of it.
Thanks for the efforts.
:smile:
To confuse the student. Really. Those evil teachers (including myself) do such things on purpose.:devil:
ehild
ehild
Really ? Well that's strange and evil for sure
Anyways , thanks for your efforts !
This is a very good picture of me. Have we met before? :smile:
ehild
ehild
No.:smile:
That is just a smiley which I think you liked.
:smile:
Thanks again.
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 28 ·
