Automotive Engineering, Stopping Distance Calculations Help?
The discussion centers on calculating the stopping distance of a vehicle weighing 3000 lbf with an initial velocity of 68 mph, using a braking system designed for constant power of 100 hp. The stopping distance was initially calculated as 420.08 feet, but this was identified as incorrect due to the need for a variable braking force to maintain constant power as speed decreases. The correct approach involves integrating the relationship between power, force, and velocity to derive the accurate stopping distance.
  • Understanding of basic physics concepts such as force, power, and energy.
  • Familiarity with vehicle dynamics and braking systems.
  • Knowledge of unit conversions, specifically between horsepower and foot-pounds per second.
  • Ability to apply calculus concepts, particularly integration, in physics problems.
  • Study the relationship between power, force, and velocity in braking systems.
  • Learn how to apply calculus to derive equations of motion in automotive engineering.
  • Research the effects of varying braking force on stopping distance calculations.
  • Explore advanced vehicle dynamics simulations to model braking scenarios.
Automotive engineers, physics students, and anyone involved in vehicle safety and performance analysis will benefit from this discussion.
eflickinger
A vehicle weighs 3000 lbf and has an initial velocity of 68 mph. If the braking system is designed to stop the vehicle at constant power, calculate the stopping distance in feet, if the stopping power is 100 hp.
m = 3000 lbf / 32.2 ft/s2 = 93.17 (lbf-s2)/ft
v = 68 mph = 68 miles/hr x 5280 ft/mile x 1hr/3600s = 99.73 ft/s
P = 100 hp = 100 hp x 550 (ft-lbf)/s / 1 hp = 55,000 (ft-lbf)/s
Fb = Braking Force
P = Energy / Time
Energy = 0.5*m*v2
Time (to stop) = t = (mv)/Fb
Distance (to stop) = x = 0.5*(m/Fb)*v2
We need to calculate x, the stopping distance.
m and v are defined, however Fb is not.
We can find the time (to stop) based on the power = energy / time equation since we have both energy and power.
Therefore, Fb = (mv)/t
Plugging back into distance (x),
0.5*(m/((mv)/t))*v2
This makes x, the stopping distance = 0.5*t*v
t = Power / Energy
Energy = 0.5*m*v2
Energy = 0.5(93.17)(99.73)2 = 463,337.81 ft-lbf
Power = 55,000 (ft-lbf)/s <-- As stated previously
Therefore, t = 463,337.81 / 55,000 = 8.42 seconds
Now plugging back into the stopping distance formula we derived:
0.5(8.42s)(99.73ft/s) = 420.08 ft
But somehow this isn't the correct answer according to my online homework (which also doesn't supply the correct answer)?
Thank You,
Evan
0.5*(m/((mv)/t))*v2
I am not sure if I follow this.
The question states that the stopping power is a constant 100hp.
As you know Power = Force x Velocity,
so as the velocity decreases when the breaks are applied, the breaking force will have to increase to keep the breaking power constant. Have you taken that aspect of the problem into consideration?
Thank you, it helped me think about it differently.
I used P = F x V => P = maV and integrated the acceleration with respect to distance and velocity to get the correct answer.
  • · Replies 28 ·
14K
