| New Reply |
Could an all water planet theorhetically exist? |
Share Thread | Thread Tools |
| Oct12-11, 08:33 PM | #1 |
Title says it all. Could a planet exist which is completely liquid water?
How about an ice core and water surface? |
| Oct12-11, 08:53 PM | #2 |
An all water planet would be highly unlikely. An accretion disc composed of mostly water would be very unusual. Accretion discs are believed to be chemically similar to the parent star. A planet with an all water surface would be quite possible.
| Oct12-11, 09:35 PM | #3 |
It would also be very strange indeed to find so much water that is so pure and stays that way for so long that no solid material accumulates to form a core.
No significant solid impurities or precipitates? If you made a planet out of nothing but ice comets, it would still be so dirty that the particulates would form a core. How would you protect this planet from the influx of meteorites? |
| Oct12-11, 09:39 PM | #4 |
How about in regards to physics? Anything in the laws of nature that would prevent it from happening? (keeping in mind that odds of it being low because of dirty comets, etc)
| Oct12-11, 09:41 PM | #5 |
If you use the term water loosely. With any size planet, the core will be crystalline ice. I think... Let me check the phase diagram of water again... Hmm. Maybe not. If it were warm enough. |
| Oct13-11, 02:33 AM | #6 |
| Oct13-11, 04:12 AM | #7 |
It is rare to impossible probability that only two elements hydrogen and oxygen only be constituents of a planet
| Oct13-11, 08:24 AM | #8 |
| Oct13-11, 11:13 PM | #9 |
| Oct14-11, 01:05 AM | #10 |
William Rowan Hamilton postulated a planet covered with extremely deep oceans and solved the differential equations for the standing waves which would form on this world. His mathematical solution is the basis of the Hamiltonian operator of quantum mechanics, describing the probability of an electron being in a particular place around a nucleus.
So, you aren't the first to wonder about this... |
| Oct14-11, 02:38 AM | #11 |
I don't think it is possible Larrybud, the pressure on the water in the centre of the planet would be so large that it would form into some sort of metallic water, and probably produce a lot of heat. I guess it depends on how small an object you want to call a planet, and how far from the sun.
An ice core seems even less likely as the centre would be hotter than the surface. What about an all gas planet? Is there some gas which is dense enough to congeal into a ball under gravity, but resistant enough to pressure to not change into liquid or sold in the centre? |
| Oct14-11, 06:55 AM | #12 |
I haven't worked it out for sure yet because it's difficult to figure out how hot the core would be without radioactive decay to keep it warm. |
| Oct14-11, 10:13 AM | #13 |
Wouldn't the water require a hygroscopic nuclei (dust particle) like rain?
| Oct14-11, 11:36 AM | #14 |
| Oct16-11, 10:22 AM | #15 |
To expand on what TGad stated:
If we compare a water planet to something like the earth. and just for a quick comparison. At the earth's core the pressure is about 330 gigapascals ( 3.5 million atmosphere, 3.5 Mbar) and temperature 5500 K. Water at that pressure and temperature is a sold, but exibits a metallic property of being able to conduct electricity with free electrons. As TGlad stated the core would be metallic solid water. Water has several other phase states besides the well known hexagonal solid, liquid, vapour that we encounter daily. For the solid the hexagonal arrangement of the water molcules at normal pressure gives the snowflake design. At different pressures and temperatures there other different solid (ice) arrangements of the molecules. So besides the metallic core, which will depend on the temperature of the core, as we move up from the center of the planet of water, various forms of ice with differnet arrangemnets of the molecules will be present, until at a lower pressure of around 1 GPa ( 10 atm ) the phase will be liquid water - that is if the temperature is above 300 K or so. ( closer to 273 k) If the temperature is below 300K then it is solid ice all the way to the surface and you have an 'ice planet". ( although, at a certain region at 200 Mpa and temperature about 250k or above , there will a layer of water between 2 layers of ice, each of a different solid phase due to the different pressures ) |
| Oct17-11, 12:06 PM | #16 |
| Oct17-11, 03:46 PM | #17 |
Wouldn't any significant mass of water have enough pressure at the center to turn to ice? Wouldn't the receipt of sufficient external heat to prevent this also boil off the water at the surface?
| New Reply |
| Thread Tools | |
Similar Threads for: Could an all water planet theorhetically exist?
| How will the water surface of this planet looks like ? | Astrophysics | 0 | ||
| How does the planet earth exist? | Earth | 2 | ||
| why does the earth have a core and can a planet exist without one? | Earth | 3 | ||
| does water molecules exist in KOH(aq)? | Biology, Chemistry & Other Homework | 1 | ||
| Is water 'discovered' on another planet hogwash? | Classical Physics | 12 | ||
