Two-dimensional kinematics: Projectile Motion
The forum discussion focuses on calculating the range of a shot-put thrown at an initial speed of 11.2 m/s from a height of 5.00 ft, using projectile motion equations. The range for launch angles of 20 degrees, 30 degrees, and 40 degrees was attempted, with calculations yielding 11.3 m, 12.78 m, and 16.48 m, respectively. The user struggled with applying the range equation correctly, particularly in separating the vertical and horizontal components of motion. Key insights include the necessity of calculating time of flight separately for each angle and using the correct equations for projectile motion.
  • Understanding of projectile motion principles
  • Familiarity with kinematic equations
  • Knowledge of trigonometric functions in physics
  • Ability to convert units (e.g., feet to meters)
  • Study the derivation and application of the range equation for projectile motion
  • Learn how to separate horizontal and vertical components of motion in projectile problems
  • Practice solving projectile motion problems with varying launch angles and heights
  • Explore the effects of air resistance on projectile motion
Students studying physics, particularly those focusing on kinematics and projectile motion, as well as educators looking for examples to illustrate these concepts.
macha9907
A shot-putter throws the shot with an initial speed of 11.2 m/s from a height of 5.00 ft above the ground. What is the range of the shot if the launch angle is a) 20 degrees, b) 30 degrees, or c) 40 degrees?
y = 1/2 gt^2
x = vt
R= Range
R = (v0^2/g)sin2(theta)
For a) 20 degrees:
t = sqrt(2y/g)
t = 1.01s
x = (11.2 m/s)(1.01s) = 11.3 m
b) R= [(11.2m/s)^2 /9.81 m/s^2] (2sin(30))
R= 12.78 m (this is incorrect..)
c) R= [(11.2 m/s)^2 /9.81 m/s^2] (2sin(40))
R = 16.48 m (this is also incorrect)
I don't really understand how I should approach this problem, or which equations I should use. The range equation is not working for me. I can't repeat the steps from part a because they did not include the angle in the first place..
I appreciate any help given.
For b) Find the time. There are two parts because one half of the parabola has a different floor height.
Code:
v[SUB]initialx[/SUB]=v[SUB]initial[/SUB]sin(θ)
v[SUB]final[/SUB]=v[SUB]initial[/SUB]+at
t[SUB]up[/SUB]=-v[SUB]initial[/SUB]/g
v[SUB]final[/SUB][SUP]2[/SUP]=v[SUB]initial[/SUB][SUP]2[/SUP]+2ad
(d+5)=1/2at2
t[SUB]down[/SUB]=√[2(d+5)/g]
t[SUB]up[/SUB]+t[SUB]down[/SUB]=t[SUB]total[/SUB]
The horizontal component maintains a constant velocity until it hits the floor.
Code:
v[SUB]y[/SUB]=v[SUB]initial[/SUB]cos(θ)
v[SUB]y[/SUB]=R/t[SUB]total[/SUB]
R=v[SUB]y[/SUB]t[SUB]total[/SUB]
I'm just a student myself so please tell me if you spot anything wrong! The steps above should apply similarly to question C as well.
yes your problem is that you aren't separating components of velocity. You can use the vertical component to calculate the time in the air. and you can use the horizontal component and the time to find the range.
