What Proportion of Pins Produced Will Be Unusable?
  • Thread starter Thread starter semidevil
    Probability
The discussion centers on calculating the proportion of unusable pins produced by a machine that creates pins of varying lengths based on the function f(y) = K(y + y^2), where y ranges from 0 to 2 cm. The correct approach involves normalizing the probability distribution by integrating f(y) over the interval [0, 2] to find the constant K, which is determined to be 3/10. Subsequently, the proportion of unusable pins is calculated as 11/20 or 0.55, contradicting the book's stated answer of 23/28, indicating a potential error in the book's solution.
  • Understanding of probability distributions and normalization
  • Familiarity with integration techniques in calculus
  • Knowledge of functions and their properties, specifically polynomial functions
  • Ability to interpret and manipulate mathematical equations
  • Learn about normalizing probability distributions in continuous functions
  • Study integration techniques for polynomial functions
  • Explore the concept of expected value in probability theory
  • Investigate common errors in mathematical problem-solving and how to identify them
Mathematics students, educators, and professionals involved in statistical analysis or quality control processes, particularly those interested in probability theory and calculus applications.
semidevil
I don't remember the exact story problem, but it goes something like this.
You are suppose to make a pin that is 6 cm long. Unfortunately, the machine will produce pins that 6 + y cm long. where 0 <= y <= 2, and the function f(y) = K(y + y^2).
if the pin is more then 7 cm long, then it is unusable. Find the proportion that is produced that will be unusable.
ok, so if y = 0, or y = 1, then it is fine, and if y = 2, then it is unusable.
so can I just integrate from 0 to 1 of f(y), and then subtract from 1, to get the answer?
the book says the answer is 23/28...but I don't know how it got that.
Not quite. It should read: If 0<=y<=1, then it is fine, and if 1<y<=2, then it is unusable.
Yes, but first, you have to find K. To get it you have to normalize the probability distribution by integrating f(y) over the sample space and setting it equal to 1. This will allow you to solve for K. Then you can do what you have proposed above.
Yes, you can integrate from 0 to 1 of f(y) and subtract it from 1 to find the proportion that is usable. This is because f(y) represents the probability that the pin will be longer than 7 cm, and we want to find the proportion that is shorter than 7 cm.
To find the proportion that is unusable, we can simply subtract the proportion that is usable from 1. So the equation would be:
1 - ∫(0 to 1) f(y)dy = 1 - ∫(0 to 1) K(y + y^2)dy
= 1 - [Ky + (Ky^2)/2] evaluated at y = 0 and y = 1
= 1 - [K(1) + (K(1)^2)/2] + [K(0) + (K(0)^2)/2]
= 1 - [K + K/2] + 0
= 1 - 3K/2
We know that y can range from 0 to 2, so we need to find the value of K that would make the integral of f(y) from 0 to 2 equal to 1.
∫(0 to 2) K(y + y^2)dy = 1
= 2K + (4K)/3
= (10K)/3
So, (10K)/3 = 1
K = 3/10
Substituting this value of K into our equation for unusable proportion, we get:
1 - 3(3/10)/2
= 1 - 9/20
= 11/20
Therefore, the proportion of pins that will be unusable is 11/20 or 0.55. This is not the same as the book's answer of 23/28, so it's possible that there was a mistake in the book's solution or in the given information.
  • · Replies 42 ·
