Commutator of density operator with kinetic energy operator
This discussion focuses on calculating the commutator relations involving the density operator ρ and kinetic energy operators in quantum mechanics. The participants successfully derived the commutators [V, ρ] and [p, ρ], with the results being (V(q') - V(q))ρ(q', q) and (d/dq'' - d/dq)δ(q' - q), respectively. The commutator [p², ρ] was also established as -(d²/dq'² - d²/dq²)δ(q' - q). Key techniques employed include integration by parts and the use of delta functions in the position representation.
  • Understanding of quantum mechanics, specifically commutation relations
  • Familiarity with the density operator in quantum mechanics
  • Knowledge of integration by parts in the context of functional analysis
  • Experience with delta functions and their properties in quantum mechanics
  • Study the implications of commutation relations in quantum mechanics
  • Learn about the role of the density operator in quantum statistical mechanics
  • Explore advanced topics in functional analysis relevant to quantum mechanics
  • Investigate the applications of delta functions in quantum field theory
Quantum physicists, graduate students in physics, and researchers focusing on quantum mechanics and operator theory will benefit from this discussion.
element_zero
Hey guys,
maybe you can help me with the following problem. I have to calculate the commutator relations in position representation:
a) [V,ρ]
b) [p,ρ]
c) [p^2,ρ]
Note that <q'|ρ|q>=ρ(q',q) is a matrix element of the density operator
I already solved the first one. You just have to apply the potential operator on a matix element of the density operator.
[V,ρ]=<q'|Vρ|q>-<q'|ρV|q>=...=(V(q')-V(q))*ρ(q',q)
The rest however is more tricky as the momentum operator is not diagonal in this domain.
[p,ρ]=<q'|pρ|q>-<q'|ρp|q>=...?
I got the hint that I should try an integration over an auxiliary variable which should lead to something like <q'|ρ|q''>~δ(q'-q'') (Delta functions)
A Fourier transformation is NOT necessary as far as I know.
The result of c should be something like:
-(d^2/dq'^2-d^2/dq^2)*ρ(q',q)
Thanks a lot for your help!
</code>For b), you can use integration by parts to get the desired result. Specifically, let <q'|pρ|q> = ∫dq'' ρ(q',q'') p(-q'')Then, integrating by parts, and using the fact that the boundary terms vanish since ρ(q',q'') is assumed to be zero at q'=±∞ and q''=±∞, we obtain<q'|pρ|q> = -∫dq'' (∂/∂q'')ρ(q',q'') (-q'') = -(∂/∂q'') ∫dq'' ρ(q',q'') (-q'')= -(∂/∂q'')δ(q'-q'') = (d/dq'') δ(q'-q'')Similarly,<q'|ρp|q> = (d/dq) δ(q'-q)Therefore,[p,ρ] = <q'|pρ|q>-<q'|ρp|q> = (d/dq'')δ(q'-q'') - (d/dq)δ(q'-q)= (d/dq'' - d/dq)δ(q'-q)For c), note that[p^2, ρ] = <q'|p^2ρ|q> - <q'|ρp^2|q>= -(d/dq'')^2 δ(q'-q'') - (-d/dq)^2 δ(q'-q)= -(d^2/dq'^2 - d^2/dq^2)δ(q'-q)
