Calculating Final Temperature of Steam and Water Mixture - Chemistry Question
  • Thread starter Thread starter GodsChild086
    Chem Energy
The discussion revolves around calculating the final temperature of a mixture of steam and water, specifically involving the heat exchange between steam at 100 degrees Celsius and water at 10 degrees Celsius. Participants are exploring the principles of thermodynamics related to phase changes and specific heat capacities.
  • Participants discuss the heat exchange equation and the importance of considering phase changes when steam condenses into water. Some express confusion about the correct application of specific heat capacities and the implications of temperature assumptions.
There is ongoing exploration of the problem, with some participants providing guidance on the correct approach to the heat exchange calculations. Multiple interpretations of the problem setup are being considered, particularly regarding the phase change of steam to water.
Some participants note the challenge of the problem, indicating that it may involve complex calculations and assumptions about the state of the substances involved. There is mention of specific values and conditions that may not have been fully accounted for in initial attempts.
GodsChild086
I'm really stuck on this question:
What will be the final temperature if 50.0 g of steam at 100 degrees celsius is mixed with 600 mL of water at 10.0 degrees celsius? (Answer: 58.3 degrees celsius)
So far I've got:
heat lost (steam) = heat gained (water)
nH + mc(delta)t = mc(delta)t
Sorry I don't know how to make the delta symbol.
(500g/18.02g/mol)(40.65 kJ/mol) + 0.500 kg(2.02 kJ/kg*C)(100-t) = 0.600 kg(4.19 kJ/kg*C)(t-10)
When I calculated everything, I didnt' get 58.3*C, so maybe someone can tell me where I went wrong in either my formulas or calculations. Thanks.
You used the specific heat capacity of steam, but after the phase change, it is water that is being cooled and no longer steam.
Try to assume that all the steam became liquid water after mixing with water.
If the value of temperature is above 100, then there are some steams left.
I got the answer now...I forgot that after when steam goes through a phase change, it is now water, not steam. Now my answer matches in one in the book. Thank you!
This is the question that I'm actually really having trouble cause I don't have a clue where to start. I think this is one of those really nasty questions.
Calculate the final temperature when 100 g of ice at -10.0*C are added to 30.0 g of steam at 110*C.
I actually sort of know where to start...but yeah, I'm very stuck on this one...
  • · Replies 44 ·
