Register to reply
Caculating heat loss from cooling fins?
Share this thread:
rsalmon
#1
Oct19-11, 04:58 AM
P: 12
Hello,
I am currently studying transformer design, in particular cooling methods.
I am tyring to calculate the cooling effect (increased heat transfer) of adding cooling fins to a transformer.
Does anyone know of some general equations/methods for calculating the increased heat radiation achieved by adding cooling fins.
Thanks,
Rob
Phys.Org News Partner Physics news on Phys.org
Vibrational motion of a single molecule measured in real time
Researchers demonstrate ultra low-field nuclear magnetic resonance using Earth's magnetic field
Bubbling down: Discovery suggests surprising uses for common bubbles
edgepflow
#2
Oct19-11, 02:25 PM
P: 688
Basically, fins increase the heat transfer rate by adding surface area. But there is an efficiency associated with the fins. The heat transfer rate is:
q_Total = Nfin * eff * hfin * Af * (Tsurface - Tsurr) + hbase * Ab * (Tsurface - Tsurr)
q_Total = heat transfer rate
Nfin = number of fins
eff = fin efficiency
hfin = convection heat transfer coefficient of fin
Af = surface area of one fin
Tsurface = surface temperature
Tsurr = surroundings temperature
hbase = convection heat transfer coefficient of base
Af = surface area of base
Notice the first term in the above equation is the heat transfer from the fin and the second term is from the base.
These calculations are a bit of an art. The trick is to make simplyfying assumptions that do not introduce too much error.
Let me know if you need help getting started.
Low-Q
#3
Oct19-11, 03:09 PM
PF Gold
Low-Q's Avatar
P: 244
Just have in mind that adding metals close to a transformer will generally reduce the transformers efficiency. When a heat sink is placed upon a toroide transformer for example, the transformer is "seeing" a short circuit secondary winding because the magnetic field wants to induce electric current through the heat sink. As the heat sink (usually made by copper or aluminum) is a good conductor, it will for sure reduce the efficiency of the transformer - which in turn makes it even hotter than without heat sink at all.
Vidar
Register to reply
Related Discussions
Loss of cooling water to condenser Mechanical Engineering 1
Temperature Fusion (heat gain = heat loss) Introductory Physics Homework 8
Heat Equation Time dependant heat loss Calculus & Beyond Homework 1
Two heat transfer questions (fins) I am unsure of Engineering, Comp Sci, & Technology Homework 0
Rate of heat loss? Speed of heat. Classical Physics 28
