De Broglie–Bohm pilot wave theory
The discussion revolves around the De Broglie–Bohm pilot wave theory and its interpretation within quantum mechanics (QM). Participants explore various interpretations of QM, particularly focusing on the implications of wave-particle duality and the behavior of macroscopic objects in quantum contexts.
  • Some participants find the Bohm theory to be the most convincing interpretation of QM, arguing against the notion that macroscopic objects behave as waves when not observed.
  • One participant proposes a thought experiment involving a ball and a double slit to challenge the wave interpretation, suggesting that if the ball does not pass through the slits, it cannot be considered a wave.
  • Another participant questions the use of a ball in the paradox, noting that the wavelength of a ball is incredibly small, making it unlikely to exhibit wave-like behavior.
  • There is a discussion about the calculations of wavelength for a ball, with some participants suggesting different approaches to the calculations.
  • Some argue that if a particle is a wave, it should not require precise conditions to be diffracted, while others counter that practical limitations exist in achieving such conditions.
  • One participant asserts that waves are merely mathematical constructs derived from observations, while others maintain that particles exhibit wave-like properties under certain conditions.
  • There are speculations about the nature of particles and their potential gravitational effects, with some participants questioning the role of gravity in wave-particle interactions.
Participants express a range of views on the validity of the Bohm theory and the interpretation of wave-particle duality. There is no consensus on whether macroscopic objects can be considered waves or the implications of such interpretations.
Participants highlight limitations in the thought experiments proposed, including the dependence on definitions of wave behavior and the challenges in observing wave-like properties in macroscopic objects.
Thenewdeal38
I have been reading about diffrent interpretations and find the bohm theory personally the most convincing interpretation of QM. I refuse to believe that my car turns into a wave when I am not looking at it. Anyways I wanted to know if there's a list that shows the number of physicists who support or disagree with the Bohm theory?
Also the idea that a say a 3 pound ball (or the moon) is a wave when its not being observed can be easly disporven. Have a room split the room in two by a steel wall then place a double slit just big enouph that the ball cannot pass through it, (start the slits at the floor and end them at the ceiling), sterilize the room, put the ball on a propulsion slingshot with a timer, clear the room of all "observers". If after the slingshot has launched the (wave ball) at the slits the ball dosent reconsitute itself on the other side the ball never acted like a wave. If the ball ends up on the other side when you check on it, head for your nearest church.
Also its facinationg that Bohm created a form of physics that argues against the "counciess observer" yet he personally beleived he was spychic. What irony!
Me too. :smile:
Of course, it's far from being perfect and it contains some yet unsolved problems too, but so do other interpretations.
You are asking a question about QM and yet you formulate the paradox with a ball. The wavelength of the ball is incredibly small this is why you will never see it behave like a wave.
Please calculate the wavelength of the ball the mass of which is m=1 kg and momentum is p=0.
I don't understand how someone can say a ball is a wave (be it a short wave) that completley ignores the geometric structures and patterns of things which obviously exist.
Why are you using p=0? You shoud instead use f = E/h, E = mc2, l = 1/f
Arent waves with very small wave length supposed to be able to pass through the slits?
I think atomthick was pointing out to the OP that the experiment, as formulated, will not accomplish the intended result. Of course atomthick is right, it won't.
They need to be small slits too! And most of the time, you won't be able to shoot it precisely enough to be diffracted. It will simply bounce off the wall, there will be no interference pattern of any kind.
And guess what, even in a standard double slit setup, some of the particles bounce back too. Nothing strange about that really.
Scuese me if it IS a wave with the proper instrumentation we should observe it act LIKE A WAVE. It either IS a wave or it ISNT, I believe its a mass of particles and that all motion is wave-like in some form or another so it move in a wave like manner.
"shoot it precisely enough to be diffracted"
1. If it is in fact a wave you shouldn't have to shoot it precisely enouphto be diffracted
2. Why would you not be able to shoot it precisley enouph, because its too big?
Sounds like a copout
I can see you imagine the associated wave spanning at infinity. It's not. A short wave length means the particle (ball) is "highly" localized. If the wave length was bigger let's say 1 meter it meant the particle (ball) could be found anyware on 1 meter radius.
The how do you explain its affront to geometric structures and patterns, a wave can't have a nuleus? A wave dosent form shape or intricate geometric shapes.
The explanation is simple. There are no waves there are just particles. Waves are something that was mathematically derived from observation (experiments) like Maxwells equations. In reality the waves are just probability distributions of how particles interact with each other. Waves are not real and it has to be accepted like that.
Oh well if you put it like that I agree. But then how does the double slit work then, do particles move in a wave like motion?
I believe no one can tell you how exactly are the particles moving. There are formulas for the interference of the associated probabilities based on the observed interaction between particles. The asociated probabilities (which happens to have a wave formula) combine each other in such a way that produces the double slit experiment result.
Imagine what happens if you take two particles that can be located anywhere on 1 meter radius (you don't know where) and you try to move them closer. It's strange but from the observations you get interference (constructive or destructive depending on the distance between the two).
"Imagine what happens if you take two particles that can be located anywhere on 1 meter radius (you don't know where) and you try to move them closer. It's strange but from the observations you get interference (constructive or destructive depending on the distance between the two)."
Could it be that each particle emits a curciular wave like gravity. And the interference is the collision of two wave like gravitys colliding into each other?
But since photons don't have mass like electrons do they also emit a gravitational field?
"A dramatic series of experiments emphasizing the action of gravity in relation to wave–particle duality were conducted in the 1970s using the neutron interferometer.[14] Neutrons, one of the components of the atomic nucleus, provide much of the mass of a nucleus and thus of ordinary matter. In the neutron interferometer, they act as quantum-mechanical waves directly subject to the force of gravity. While the results were not surprising since gravity was known to act on everything, including light (see tests of general relativity and the Pound-Rebka falling photon experiment), the self-interference of the quantum mechanical wave of a massive fermion in a gravitational field had never been experimentally confirmed before."
I don't think gravity has something to do with it. For example in your question the ball can't get through the double slit unless you move the wall very close to the ball (because the ball has a very short wave length therefore it's localized in a very short range of space). If gravity was to play a part in this then wave length would be larger because the ball has a bigger mass.
exellent point
"the ball can't get through the double slit unless you move the wall very close to the ball"
Still I don't thinks this is possible. Even if you put the ball right up against the slits and had a machine that pushed the ball against those slits.
Even if you created a vacuum system I am pretty sure it wouldn't work.
Before picking interpretations I suggest you study more the actual physics.
In your steel balls example let me point out that to observe quantum phenomena you'll need to cool the balls down to absolute zero, and carry out many many experiments to see the interference pattern in the distribution of where the balls end up.
Your description of what non-Bohmian interpretations say or predict is inaccurate. Note this most of all, the various interpretations make no distinction about what we will physically observe in the laboratory and thus are not competing theories, only competing philosophical points of view about what if anything is going on behind what we can see.
But particles move in a wave like motion right?
People on this forum are saying that the moon isn't there when it isn't being observed! And they say that the copenhagen interpretation proves it. How is this not a non-Bohmian interpretation.
Anyways
"Waves are shown to be the only means of describing motion, since smooth motion on a continuum is impossible. If a particle visits every point on its trajectory then the motion is an algorithm for each point. Turing[29] has shown that almost all numbers are non-computable, which means that there is no possible algorithm, so the set of points on a trajectory is sparse. This implies that motion is either jerky or wave-like. By removing the need to load the particle with the properties of space and time, a fully deterministic, local and causal description of quantum phenomena is possible by use of a simple dynamical operator on a Universal Invariant Set. Evidently, quantum particles are indeed particles, but whose behaviour is very different from classical physics would have us to expect."
"By removing the need to load the particle with the properties of space and time" This is the only part that confuses me. Can someone explain what they mean by this?
Who among us here who as actually studied QM seriously has said that? Link to a specific post, please.
You're right. It really happens like you say. The ball moves up and down like a wave and goes through the slit, forming an interference pattern.
Just kidding. :biggrin:
Thenewdeal38 said:
People on this forum are saying that the moon isn't there when it isn't being observed! ...
As jtbell points out, this is not a statement being made by physicists. You are confusing Einstein's analogy with a literal comparison. Particles do NOT* have well-defined PROPERTIES independent of the act of observation. So the better analogy is that the Moon is not yellow when it is not being observed - it is only yellow when observed as such. But it is still somewhere at all times.
*Keeping in mind this is interpretation dependent.
People on this forum say lots of things between utter nonsense and profound truth...just as in the rest of the world. If you're going to cite "people on this forum" it would do well to be more specific. Others can then determine if they indeed are uttering nonsense or if you are misreading what they are saying, (or --of course-- if you and/or they are uttering profound truths.)
As far as what the Copenhagen interpretation says, that too can depend on who you ask. As I understand it, CI rejects the postulate of a fundamental objective reality.
Understand then that when referring to "reality" one is invoking a classical model and not asserting an ontological position. I find it helps to replace the word "reality" = "what is" with "actuality=what happens".
In that sense it is just as wrong to assert that the moon ceases to exist (in an objective state) when not observed as it is to assert that the moon continues to exist (in an objective state) since either statement is presupposing facts not in evidence through empirical observation.
What CI rejects is statements about the Moon's state (or an electron's) apart from statements linked to observational events.
"The moon is there = There is the moon!",
"The moon is not there = I see a space where the moon used to be!"
Anyways
"Waves are shown to be the only means of describing motion, since smooth motion on a continuum is impossible. ..."
Who are you quoting here?
Thenewdeal38, I’m glad you like the De Broglie–Bohm theory. It’s my favorite too. But I intentionally took a while to settle on it. I felt that if I picked one it’s because of belief since I really didn’t know enough. Even now I know that my choice is still just a matter of taste. There are many PF members here with an actual physics degree that prefer many worlds. And many more prefer Copenhagen. And out of those, there’s a bunch that prefer “Shut up and calculate.”
https://www.physicsforums.com/poll.php?do=showresults&pollid=1995
They all have their reasons. Einstein certainly had his reasons for saying, “I refuse to believe that the moon does not exist when we don't observe it.” But this was an extreme generality used in a much more nuanced argument. I think I recall Bohr had better language for these non-classical physics type discussions.
I’ll give you an example. I have been performing an experiment on my wife. Each day I wake up, I check to see if my wife is still alive and then I make a note of it. I did this 100 times and each time she was alive. I tried some statistics and I thought maybe she will live forever. But maybe my sample size isn’t large enough. So I did it 500 times and then 1000. I now have collected 5000 observations and I can now tell you with absolute certainty that my wife will live forever. What is wrong with my logic?
Here’s another one: What exactly are the properties of an electron before you measure them? This question has a totally different meaning when you’re talking about classical physics and when you’re talking about quantum mechanics.
So I think you should reconsider jambaugh’s suggestion for a little longer.
Science proves nothing, not a thing. It can only tell you the likelihood. Principals and laws tell you what's really really likely. But they are still not proof.
jtbell said:
Who among us here who has actually studied QM seriously has said that? Link to a specific post, please.
Just to be clear, (JTBell and DrChinese, please correct me if I’m wrong), according to any interpretation of QM, there is a very, very, VERY remote possibility that the entire moon truly is no longer there just when you are not looking at it. Who could possibly imagine an entire BB, let alone the moon blinking out of existence. It’s a very remote possibility but it’s still possible. So how do you know that hasn’t happened if you don’t look out the window? (Caution: I have not actually studied QM seriously.)
If you’re ready to have your noodle cooked even more, then you should look into quantum tunneling.
http://en.wikipedia.org/wiki/Quantum_tunneling
And this!
http://en.wikipedia.org/wiki/Casimir_effect
  • · Replies 23 ·
