| Thread Closed |
Hydrogen as a fuel |
Share Thread | Thread Tools |
| Nov26-04, 08:25 AM | #1 |
Hydrogen as a fuel
Is it possible to create a structure where
1)water is electrolysed into oxygen and hydrogen 2)Hydrogen is burnt in the same oxygen obtained from step 1 3)This releases lot of energy and forms water 4)This energy can be used to rotate the armature of an electric generator 5)Electricity can be produced 6)The water in step 3 can be used in step 1
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Nov26-04, 01:06 PM | #2 |
Yup, yup, yup, yup, yup, and yup. Will "5" take care of "1"? Nope.
| Nov26-04, 02:08 PM | #3 |
Mentor
Since the reaction is symmetrical (water+energy=hydrogen+oxygen=water+energy, etc, etc, etc.), even if you had perfect efficiency, you'd still never get more energy out than you put in.
| Nov26-04, 05:15 PM | #4 |
Hydrogen as a fuel
Let's do the math here and see what falls out. Per Faradays constant of electrolysis, it takes about 96,500 coulombs to generate 1 mole of hydrogen gas. After a couple of crunches, it appears to require about 32.9 kilowatts to generate 1 kilogram of hydogen gas. The electrical energy equivalent of a kilogram of hydrogen gas is 33.5 kilowatts. That looks promising, 102% efficiency!
Aye, but there is a rub, as usual. Those are idealized numbers - i.e., they assume 100% efficiency. You can take 17% straight off the top in heat loss. Now the numbers look like this 32.9 x 1.17 and 33.5 x 0.83 = 38.5 kw to get 29.1 kw.. down to 75% efficiency. And this is at laboratory efficiencies. In the real world, the true loss is about 1/3, so the real world efficiency is in the neighborhood of 50%. The bad news is you will run out of gas. The good news is it ain't all that bad a return. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Hydrogen as a fuel
| Is this hydrogen fuel technology possible? | General Engineering | 36 | ||
| how do you make hydrogen fuel | Biology, Chemistry & Other Homework | 1 | ||
| Hydrogen fuel cells! | Materials & Chemical Engineering | 2 | ||
| Hydrogen Fuel Cell | Chemistry | 9 | ||
| Hydrogen Fuel Cells | Electrical Engineering | 3 | ||
