Explain why when you have two physical pendula
  • Context: Undergrad
  • Thread starter Thread starter daveed
    Explain Physical
When comparing two physical pendula of equal length, one with a weight positioned 2/3 down the rod and the other without additional weight, both fall at the same rate. The kinetic energy of each section of the pendulum is proportional to its speed squared, leading to the conclusion that the total kinetic energy can be calculated by integrating the function x² from 0 to L. The resulting kinetic energy for the uniform bar is equivalent to that of a simple pendulum of length 2/3L, governed by the equations τ = I α and T = 2 π √(L/g) for small angles.
  • Understanding of physical pendulum dynamics
  • Familiarity with torque (τ) and rotational inertia (I)
  • Basic knowledge of calculus, specifically integration
  • Concept of simple harmonic motion and pendulum equations
  • Study the derivation of the period for simple pendulums using T = 2 π √(L/g)
  • Explore the differences between simple pendulums and physical pendulums
  • Learn about the implications of mass distribution on pendulum motion
  • Investigate the effects of varying pivot points on pendulum dynamics
Physics students, educators, and anyone interested in the mechanics of pendulum motion and energy distribution in physical systems.
daveed
can someone explain why when you have two physical pendula, one of which has a weight 2/3 of the way down falls at the same rate as one without a weight but is the same length?
The kinetic energy gained by each small section of the bar is proportional to its speed squared, and the speed varies linearly with the distance from the pivot point.
So to calculate the total kinetic energy of the whole bar, you integrate a function of x^2 between zero (at the pivot) and L, where L is the length of the bar.
Integral of x^2 is 1/3 x^3
Set L = 1 and the integral becomes 1/3
So the kinetic energy of the pivoting uniform bar is the same as if all its mass were concentrated at 1/3 of the distance from the pivot point.
The rod with the weight at 2/3 L can be approximated as a simple pendulum of length 2/3 L. The rod without the added weight cannot and must be treated as a physical pendulum (a uniform rod).
The equation governing the pendulum is this:
[tex]\tau = I \alpha[/tex]
For a simple pendulum of length L, for small angles:
[tex]mg L \theta = m L^2 \alpha[/tex]
or:
[tex]\alpha = g/L \theta[/tex]
The solution to this differential equation gives the period of the simple pendulum as:
[tex]T = 2 \pi \sqrt{L/g}[/tex]
For the uniform rod, the torque and rotational inertia differ:
[tex]mg L/2 \theta = 1/3 m L^2 \alpha[/tex]
[tex]\alpha = g/(2/3L) \theta[/tex]
Which gives a period of:
[tex]T = 2 \pi \sqrt{(2/3)L/g}[/tex]
Which is equivalent to a simple pendulum of length 2/3L.
  • · Replies 22 ·
  • · Replies 22 ·
  • · Replies 20 ·
  • · Replies 18 ·
