What Steps Are Needed to Prove That a Number Is the Supremum?
  • Thread starter Thread starter semidevil
The discussion revolves around proving that a number is the supremum, specifically focusing on the set {1 - 1/n} for natural numbers n. Participants explore the concept of supremum as the least upper bound and the necessary conditions to demonstrate that a number qualifies as such.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the two main conditions needed to prove that 1 is the supremum: establishing that 1 is an upper bound and finding elements in the set that are arbitrarily close to 1. Questions arise about the clarity of the original poster's reasoning and the organization of their proof.
Some participants provide guidance on the steps needed to demonstrate that 1 is the supremum, noting that the original poster has made progress but may need to clarify their justification and organization. Multiple interpretations of the proof steps are being explored, particularly regarding the relationship between upper bounds and the supremum.
There is a mention of needing to justify why 1 is considered an upper bound, as well as a discussion about the implications of different inequalities related to the elements in the set.
semidevil
ok, so supermum is the least upper bound, but when you write down on paer, what am I trying to show...does that make sense? I mean, what am I trying to get to that will show something is the supermum.
so for example: prove sup {1 - 1/n} = 1 for all n in N.
so I start by saying that I know that 1 is an upper bound...
then, for all epsilon > 0, there exist n st n > epsilon, or 1/n < epsilon.
ok, now what...how else do I need to go to show that 1 is supermum...
how do I know that I have shown that 1 is the supermum??
To show 1 is a supremum you need to show 2 things,
a) that 1 is an upper bound for your set
b) that you can find points in your set arbitrarily close to 1, That is for every [tex]\epsilon>0[/tex] there is an [tex]x[/tex] in your set where [tex]1-\epsilon<x[/tex].
That's all. It appears you've done both of these steps, but your organization seems unclear. Do you understand how what you've done relates to the above?
An alternate to b) above, you can instead prove
b*)if A is any other upper bound for your set, then 1<=A
Show that the number is an upperbound AND any number smaller is NOT an upperbound.
I dotn know what I've done to solve the problem...can you tell me what I did? lol...how haev I already solved the problem?
btw, is 1 - e < x the same as 1/e < x?
This is condition a), though you should should give some justification as to why 1 is an upper bound.
This is b), but it needs some explanation. To prove b), let [tex]\epsilon >0[/tex] and we want to find something in our set that's larger than [tex]1-\epsilon[/tex]. You've shown that there is an [tex]n\in\Bbb{N}[/tex] where [tex]1/n<\epsilon[/tex]. Now you know that [tex]1-1/n[/tex] is in your set and the last inequality tells us that [tex]1-1/n>1-\epsilon[/tex], and we've found an element in our set and condition b) is satisfied.
No. Try e=1/2, x=1.
  • · Replies 16 ·
