Is it safe to loop the inverter's output neutral to loop with the mains neutal?
Looping the inverter's output neutral with the mains neutral is unsafe and can lead to equipment damage, as evidenced by a user who experienced a fire spark at the inverter's output terminal. The user connected one output terminal of the inverter to the mains supply neutral, but failed to properly isolate the other terminal, which likely connected to the system phase. This improper connection resulted in a short circuit, damaging the inverter. Proper wiring practices must be followed to prevent such incidents.
  • Understanding of inverter wiring configurations
  • Knowledge of electrical phase and neutral connections
  • Familiarity with electrical safety standards
  • Experience with troubleshooting electrical equipment
  • Research proper inverter wiring techniques and configurations
  • Learn about electrical phase and neutral relationships in AC systems
  • Study electrical safety standards and best practices
  • Explore troubleshooting methods for electrical equipment failures
Electricians, electrical engineers, and anyone involved in inverter installation or maintenance will benefit from this discussion.
rozan977
Is it safe to loop the inverter's output neutral to loop with the mains neutal??
Guys, I need a help on this. I thought that it is rather safe to loop one of the output terminal of the inverter to loop with the mains supply inverter, so that there doesn't arise the need of extra neutral wiring for the appliance. I did the same, but something went wrong and as soon as I plug into charge the battery for inverter the, inverter got damaged with a fire spark on its output terminal. I am really confused on what went wrong?
I couldn't understand exactly how you connected things (what is "mains supply inverter"?). A figure could help.
When you plugged in the inverter to the mains, I guess, one of the output terminal of the inverter was connected to the system neutral; what about the other terminal?
Perhaps you you connected it to the system phase; hence the sparking.
12K
13K
  • · Replies 79 ·
18K
