Help Easy Physics - Resistivity Ratios
The discussion revolves around the resistivity and density of Aluminium and Copper, specifically focusing on calculating the mass ratio of Aluminium to Copper for equal length and resistance in a physics context.
  • The original poster attempts to determine the mass ratio based on given resistivity and density ratios, expressing uncertainty about the calculations. Some participants suggest using the formula for resistance to explore the implications of wire thickness and volume on mass.
Participants are actively engaging with the problem, with some providing insights into the relationships between density, volume, and mass. There is a recognition of the need for further information to complete the calculations, and multiple interpretations of the problem are being explored.
There is an indication that the original poster feels uncertain about their physics knowledge and the adequacy of the information provided for solving the problem.
I-need-help
The resistivity of Aluminium is twice that of copper. However, the density of Aluminium is one-third that of Copper.
a) For equal length and resistance, calculate the ratio:
mass of aluminium/mass of copper​
I'm thinking, the density ratio (Al:Cu) is 1:3 ...and the resistivity ratio is 2:1 ...so would the overall ratio be, 2:3 ? I have no idea...
This is easy Physics compared to what else is on this site, but my physics isn't any good, so I joined this forum in hope that someone would be able to help me!
Thank you :)
Thank you :)
refer to the formula of resistance - often given as R = ρL/A - to see that one of the wires will have to be thicker - thus have a greater volume of metal, thus greater mass than if it was the same thickness.
Okay, thank you. I understand that, I'm just not sure how to get a ratio from that, with no other information... I'm not even sure if I need to work out a ratio actually. Oh well, thanks anyway.
Firstly, your original answer 2:3 was correct - but your uncertainty indicated you were not sure why.
When doing ratios, I just use the formulas and do a grand divide to produce the ratio.
In this case we want the ratio of masses.
Well I know density is mass/ volume [ σ = M/V] so
M = Vσ
Now the ratio: firstly put subscripts on the variable - I would use c for copper and a for aluminium
Ma = Vaσa
and
Mc = Vcσc
In ratio form:
Ma/Mc = Va/Vc x σac
We thus know
Ma/Mc = Va/Vc x 1/3
since we were given the ratio of the densities.
So now we need the ratio of the Volumes to complete this.
Each wire is effectively a cylinder
V =πr2h
For the wire, h = length of the wire - which is the same for both wires - so the ratio reduces to.
Va/Vc = ra2/rc2
So now we need the ratio of Radii [or diameters?]
Resistance is given by"
R = ρL/A
Since Area here is that of the circular wire,
R = ρL/∏r2
transposing
r2 = ρL/∏R
This gives
ra2 = ρaLa/∏aRa
and
rc2 = ρcLc/∏cRc
Now for these wires, Length and resistance [and of course ∏] are the same, so the ratio simplifies to
ra2/rc2 = ρac
Substituting back into:
Va/Vc = ra2/rc2
gives
Va/Vc = ρac
Then back into:
Ma/Mc = Va/Vc x 1/3
gives
Ma/Mc = ρac x 1/3
which gives
Ma/Mc = 2 x 1/3
which is 2/3 or 2:3 if you like.
While this has been lengthy to type out, when written it is much quicker.
Note: Normally the line:
ra2/rc2 = ρac
would be expressed as
ra/rc = √[ρac]
but I knew my previous formula had ra2/rc2 in it so I left it as was.
You can use this ratio technique to find the ratio of anything:
eg Ratio of two accelerations
F = ma → a = F/m
so
a1 = F1/m1
and
a2 = F2/m2
a1/a2 = F1/F2 x m2/m1
[Note that since m was in the denominator, is appears "upside down" as a ratio.]
SO once we know the ratio of the forces, and the ratio of the masses we can work out the ratio of the accelerations, without calculating/knowing the actual value of each acceleration.
Ahhhh okay, thanks so much for your help. Much appreciated. :)
  • · Replies 47 ·
