Calculating the Change in Kinetic Energy During a Collision
The discussion focuses on calculating the change in kinetic energy during a collision between two pucks on a frictionless air table. Puck A, with a mass of 0.366 kg, initially moves towards puck B, which has a mass of 0.254 kg and is at rest. After the collision, puck A moves at -0.119 m/s, while puck B moves at 0.655 m/s. The participants clarify that the change in kinetic energy should be calculated as the difference between the final and initial kinetic energies, emphasizing the conservation of linear momentum for accurate results.
  • Understanding of linear momentum conservation
  • Familiarity with kinetic energy formulas
  • Basic knowledge of elastic and inelastic collisions
  • Ability to perform calculations involving mass and velocity
  • Study the principles of elastic vs. inelastic collisions
  • Learn how to derive kinetic energy equations for different scenarios
  • Explore the concept of momentum conservation in multi-body collisions
  • Practice problems involving kinetic energy changes in collisions
Physics students, educators, and anyone interested in understanding collision dynamics and energy transformations in mechanical systems.
disruptors
On a frictionless horizontal air table, puck A (with mass 0.366 kg) is moving toward puck B (with mass 0.254 kg ), which is initially at rest. After the collision, puck A has velocity 0.119 m/s to the left, and puck B has velocity 0.655 m/s to the right.
What was the speed of puck A (Vai) before the collision?
K I put v=v1(m1+m2)/(m1-m2)
v1=-.119 m/s since it moves in the left direction and i defined right as +ve
my initial velocity of puck a came to be -0.659 m/s, but it seems to be wrong.
Calculate , the change in the total kinetic energy of the system that occurs during the collision.
for the KE I got 0.333 J but I don't know why its wrong
thx guys
Since puck B is initially at rest, the initial linear momentum of the system is: m1*v
After the collision, the linear momentum will be equal to: m1*v1 + m2*v2
Since linear momentum is conserved, the initial and final linear momentums will be equal. Once you equate these, you can solve for v.
Hope this helps,
zoetrope
yeah that helps thanks
i was looking at it as an inelastic collision
for the energy part i am using the equation
1/2 m1 v1(squared)i = 1/2 m1 v(squared)1f + 1/2 m2 v(squared)2f
question is looking for change in kinetic energy DURING collision
i calculated Final KE - Initial KE but is that not considered the total change in KE DURING the collision?
  • · Replies 29 ·
  • · Replies 22 ·
