| New Reply |
A two Variable PDE |
Share Thread | Thread Tools |
| Oct25-11, 06:47 AM | #1 |
Recognitions:
A two Variable PDE
In an open domain in the plane
(xU[itex]_{x}[/itex]-yU[itex]_{y}[/itex]-U)/U = (xV[itex]_{x}[/itex] - y V[itex]_{y}[/itex]+V)/V |
| Oct25-11, 08:25 PM | #2 |
I'd like to know the answer myself. Does [itex]\frac{xU_x}{U}-\frac{xV_x}{V}=\frac{yU_y}{U}-\frac{yV_y}{V}[/itex] make it any easier? I've only dabbled in PDEs myself, but that seems like a separation of variables problem, when rephrased like that.
EDIT: Mathematica gives an error saying the answer is indeterminate, because there are more dependent variables than equations. |
| Nov1-11, 02:34 PM | #3 |
Recognitions:
Also the answer is a little trivial. |
| Nov1-11, 03:26 PM | #4 |
A two Variable PDE
So you have:
x d/dx ln (U) -y d/dy ln(U) -1 = xd/dx ln (V) -y d/dy ln(V) +1 x d/dx (ln(U/V))=y d/dy (ln(U/V))+2 Now make a guess of a function of the type U/V = exp(F(x,y)) to get: x d/dx F = y d/dy F +2 so you have x d/dx F -y d/dy F =2 d/dx (xF) - d/dy (yF) = 2 Don't see how to solve this, though. p.s the derivatives above are partial btw. |
| Nov1-11, 03:32 PM | #5 |
Recognitions:
[tex]x \partial_x (\log U) - y \partial_y (\log U) - 1 = x \partial_x (\log V) - y \partial_y (\log V) + 1[/tex] or [tex]x \partial_x (\log U - \log V) - y \partial_y (\log U - \log V) = 2[/tex] Define some function [itex]e^f = U/V[/itex] and you have [tex]x \partial_x f - y \partial_y f = 2[/tex] which should be easy to solve by characteristics. Mathematica gives [tex]f = 2 \log x + C x y[/tex] for arbitrary C. Then U and V can be any functions satisfying [tex]\frac{U}{V} = x^2 e^{C x y}[/tex] |
| Nov1-11, 03:57 PM | #6 |
Recognitions:
Thanks Ben
What approach would you recommend to learning more about differential equations? Right now i am learning differential geometry. |
| Nov1-11, 04:04 PM | #7 |
Recognitions:
I don't know, I taught myself the method of characteristics when I started running across problems in my research that needed it.
| Nov1-11, 10:13 PM | #8 |
Sometime I wonder why I even bother answering. :-/
| Nov12-11, 03:07 PM | #9 |
Recognitions:
I thank you for this solution and feel that I should explain where this equation came from.
To learn some differential geometry I posed the question of what vector fields on a surface can be tangent to geodesics for some Riemannian metric. Computation led to the condition that a unit length vector field V is tangent to geodesics if its Lie bracket with iV, the unit vector field orthogonal to it, is a multiple of iV (and that this multiple satisfies a differential equation along the geodesic that relates it to the Gauss curvature of the metric). For the vector field xd/dx - yd/dy in a neighborhood of the origin in the plane, one gets the differential equation in this post. I think your solution shows that the field of hyperbolas y = k/x can be geodesics and that iV can be chosen to be x[itex]^{2}[/itex]d/dx + e[itex]^{-xy}[/itex]d/dy. So it seems that a vector field of index -1 around a singularity can be a geodesic flow. I think the Gauss curvature is -1 for this example but I haven't yet done the ugly calculation. |
| New Reply |
| Thread Tools | |
Similar Threads for: A two Variable PDE
| Solving For A Variable In Multi-Variable Equations | General Math | 6 | ||
| Natural log of a variable times the variable | General Math | 3 | ||
| Numerical Integration of a 2-variable function in Matlab with respect to 1 variable | Math & Science Software | 1 | ||
| Are Toasters Heat Variable or Time Variable? | General Physics | 2 | ||
| Matlab: Use string variable as variable name | Math & Science Software | 5 | ||
