Why Does Lorentz Transformation Not Yield the General Form of Four-Acceleration?
  • Context: Graduate
  • Thread starter Thread starter snoopies622
The discussion revolves around the application of Lorentz transformations to the four-acceleration vector, specifically questioning why the transformation does not yield the general form of four-acceleration from a specific case in an instantaneous co-moving inertial frame. The scope includes theoretical considerations of special relativity and the mathematical implications of transformations.
  • One participant states that in an instantaneous co-moving inertial frame, the four-acceleration vector reduces to (0,a).
  • Another participant argues that a general result cannot be derived from a special case, noting that the simple form (0,a) is only valid for a small lapse of time.
  • A participant expresses difficulty in conceptualizing the Lorentz transformation as anything other than a rotation, questioning the correspondence between vectors in different frames.
  • One participant mentions that while the Lorentz transformation seems to work for four-momentum, they are unsure how it applies to four-acceleration.
  • Another participant suggests that graphing the transformation in a specific way reveals a rotational aspect, although they acknowledge this view may be misleading.
Participants express differing views on the nature of Lorentz transformations and their implications for four-acceleration, with no consensus reached on the conceptualization of these transformations or their mathematical consequences.
Participants highlight limitations in their understanding of the Lorentz transformation, particularly regarding its application to different frames and the nature of the four-acceleration vector. There is an acknowledgment of the complexity involved in transitioning from special to general cases.
This discussion may be of interest to those studying special relativity, particularly in understanding the nuances of Lorentz transformations and their implications for four-vectors in different inertial frames.
snoopies622
In an instantaneous co-moving inertial frame, the four-acceleration vector reduces to (0,a).
Why then does applying a Lorentz transformation to the above vector not produce the general form?
That's because the co-moving frame has a changing speed,
and because a general result cannot be obtained from a special result.
The simple form (0,a) is valid only for a small lapse of time.
Using the full expression for the acceleration at any time in the once-co-moving frame,
would allow you to derive the expression in any other frame.
The general expression is Lorentz invariant.
lalbatros said:
...a general result cannot be obtained from a special result.
Yes, that makes sense to me. The problem I'm having is one of imagination. I have always pictured the Lorentz transformation as a kind of rotation. So I imagine a (0,a) vector being rotated from one position to another, and a one-to-one correspondence between a vector in the v=0 frame and the set of the same vector in all the other frames.
I know it works for four-momentum. That is, if one starts with the specific v=0 case [itex]m_0 (c,0)[/itex] and Lorentz transforms it, it turns into the general case
[tex]\gamma m_0 (c,\bf {v})[/tex]
I will give it more thought.
Are you able to explain that? Most people seem to picture & refer to it as a rotation, but I can't envision it.
Well, if you graph xi ([itex]i^2 = -1[/itex]) on the horizontal axis versus ct on the vertical, then it's a rotation, and the angle is the rapidity. I suspect that some find that idea objectionable - it's misleading in some ways - but I still like it.
Correction: the angle is rapidity times i. Pretty weird, yes.
  • · Replies 22 ·
  • · Replies 101 ·
