| New Reply |
Am I missing something? |
Share Thread | Thread Tools |
| Oct26-11, 08:56 PM | #1 |
For our typical quadratic equation:
x= (-b± [itex]\sqrt{b^2-4ac}[/itex])/2a Am I missing something? I mean the value underneath the square root turns out to be a negative number, so technically this equation would not have worked right? It's from a textbook by the way. This is actually an analytical chemistry application question. x= -6.8*10-4 ± [(6.8*10-4)2 - (4)(6.8*10-4)]0.5/(2)(1) |
| Oct26-11, 09:02 PM | #2 |
Recognitions:
The equation works fine with negative numbers. Sometimes this happens when the roots should be real, either a mistake was made or the situation modeled is impossible or there was rounding and the roots returned are barely complex and should be rounded back to real.
| Oct26-11, 11:08 PM | #3 |
is b = c ?
or did you write the wrong value? In any case, negative ARE possible and you go into complex number territory |
| Oct26-11, 11:18 PM | #4 |
If a proper math equation (which this is) is applied in a way that doesn't give a physically possible answer, that's not the math's fault and you need to look at whether or not the right numbers have been put in or whether perhaps the equation is not the right one to use in a given situation.
| New Reply |
| Thread Tools | |
Similar Threads for: Am I missing something?
| I must be missing something... | Calculus & Beyond Homework | 1 | ||
| What am I missing here? | Introductory Physics Homework | 2 | ||
| Missing Matter, Missing Energy? | Cosmology | 8 | ||
| Missing ET | High Energy, Nuclear, Particle Physics | 0 | ||
| Am I missing something ? | Quantum Physics | 4 | ||
