Optimizing Solar Panel Power Output: Calculating dP/dt and θ'(t)
  • Thread starter Thread starter IntegrateMe
The discussion focuses on optimizing solar panel power output by calculating the derivative of power with respect to time, dP/dt, using the chain rule. The power output function P(θ) is dependent on the angle θ(t), which varies throughout the day. Participants calculated θ'(t) using the function θ(t) = arcsin(t/7 - 1) + π/2 and discussed the implications of dP/dθ at specific times. The change in power output between 4:30 PM and 5:30 PM was clarified to be the difference in power values at those times, necessitating the integration of the power function.
  • Understanding of calculus, specifically differentiation and the chain rule
  • Familiarity with trigonometric functions and their derivatives
  • Knowledge of solar panel operation and power output principles
  • Ability to integrate functions to find total change over an interval
  • Study the application of the chain rule in real-world scenarios
  • Learn about solar panel efficiency optimization techniques
  • Explore integration methods for calculating area under curves
  • Investigate the impact of angle of incidence on solar energy capture
Students and professionals in renewable energy, engineers working on solar technology, and anyone interested in the mathematical modeling of solar power systems.
IntegrateMe
The power output of a particular type of solar panel varies with the angle of the sun shining on the panel. The panel outputs P (θ) watts when the angle between the sun and the panel is θ for 0 ≤ θ ≤ π. On a typical summer day in Ann Arbor, the angle between a properly mounted panel and the sun t hours after 6 a.m. is θ(t) for 0 ≤ t ≤ 14. Assume that sunrise is at 6 a.m. and sunset is 8 p.m.
(A) Calculate dP/dt using the chain rule, and give interpretations for each part of your calculation.
P(θ(t)). So, dP/dt = P(θ(t))' = P'(θ(t)) * θ'(t)
P'(θ(t)) is the average rate of change of power with respect to θ.
θ'(t) is the average rate of change of θ with respect to t.
(B) Suppose θ(t) = arcsin(t/7 -1) + π/2. Calculate θ'(t) using the equivalent expression: sin(θ(t) - π/2) = t/7 - 1
I just differentiated the equivalent function:
cos(θ(t) - π/2)*θ'(t) = 1/7
θ'(t) = 1/(7*cos(θ(t) - π/2))
(C) Suppose dP/dθ (2π/3) = 12 and θ(t) is the function in part (B). Find the change in power output between 4:30PM and 5:30PM.
This is where I'm having trouble. I would think the "change in power output" would simply be dP/dθ, since this represents the change in power with respect to θ, but I feel as though I'm incorrect here. Any help would be awesome. Thanks!
bump!
I don't know what they mean by the change in power output. Probably it's P(5:30 PM) - P(4:30 PM), since a change is just a variation of a function. In that case you have to find P(t), integrating the expression in (A).
Sorry if this didn't help :-p
  • · Replies 21 ·
  • · Replies 38 ·
