How to find the cosine between the directions
  • Thread starter Thread starter moose02
    Cosine
The discussion focuses on calculating the work done by a horizontal force of 100 N while pushing a box up a ramp. The work is determined through three methods: (a) using the dot product of the force and displacement vectors, yielding 400 J, (b) applying the formula W = Fs cos θ, where θ is the angle of the ramp, and (c) finding the component of displacement in the direction of the force. The inclination angle of the ramp is crucial for accurately calculating the work done in parts (b) and (c).
  • Understanding of vector components and dot products
  • Knowledge of trigonometric functions, specifically cosine
  • Familiarity with work-energy principles in physics
  • Ability to visualize and interpret force and displacement vectors
  • Learn how to calculate the angle of inclination of a ramp using trigonometric ratios
  • Study the concept of vector projections to understand force components
  • Explore the relationship between work and energy in physics
  • Practice problems involving work done by forces at angles
This discussion is beneficial for physics students, educators, and anyone seeking to deepen their understanding of work calculations involving forces and angles in mechanical systems.
moose02
I really need some help on this one:
You push a box up a ramp using a horizontal 100-N force F. For each 5m of distance along the ramp the box gains 3m of height. Find the work done by F for each 5m it move along the ramp (a) by directly computing the dot product from the components of f and the displacement s, (b) by multiplying the product of magnitudes of f and s with the cosine of the angle between their directions (c) by finding the component of the displacement in the direction of the force and mulitplying it by the magnitude of the force.
I am pretty sure I know how to find the first part which is just
W=F*(5m i + 3m J) which would be 100N*5m + 100N*3m but I have no clue on the other two parts. For part b I am not sure how to find the cosine between the directions, I know the magnitude of F and is the magnitude of s just 5m + 3m? Any hints are greatly appreciate as I do not even know where to start. Thankyou
If I understand the question correctly then the work done in part (a) is given by [itex]W=\vec{F} \cdot \vec{s} = (100N\hat{\imath} + 0N\hat{\jmath}) \cdot (4m \hat{\imath} + 3m \hat{\jmath}) = 400J[/itex]. (b) [itex]W = Fs\cos\theta = (100 N)(5 m)\cos\theta[/itex]. I suppose they gave you an inclination angle [itex]\theta[/itex] of the ramp that you can substitute in. Otherwise you can use the value of [itex]F[/itex] calculated in part (a) to find [itex]\cos\theta[/itex]. (s) [itex]W = F_xs_x = (100N)(4m) = 400J[/itex]
To find the cosine between two directions, you will need to first find the angle between them. In this case, the angle between the directions of the force and the displacement is the angle of the ramp, which we can call θ.
For part (b), you can use the formula W = Fscosθ, where Fs is the magnitude of the force and θ is the angle between the force and displacement directions. In this case, Fs would be 100N and θ would be the angle of the ramp.
For part (c), you can use the formula W = Fdcosθ, where Fd is the component of the displacement in the direction of the force. In this case, Fd would be the magnitude of the displacement (5m + 3m) multiplied by the cosine of the angle of the ramp.
I hope this helps! Remember to always draw a diagram and label all the given information to help you visualize and solve the problem. Best of luck!
  • · Replies 56 ·
