Convergence and Divergence of the Sequence nsin(npi)
The discussion revolves around the convergence or divergence of the sequence defined by nsin(nπ) as n approaches infinity. Participants are exploring the behavior of this sequence and its limit properties.
  • Some participants inquire about the appropriate methods to analyze the sequence, such as the squeeze theorem or L'Hôpital's rule. Others suggest evaluating the function at specific integer values to identify patterns. There are also requests for algebraic approaches to the problem.
The discussion is active, with participants sharing different perspectives on how to approach the problem. Some guidance is offered regarding evaluating the sequence at specific points, while there is a mix of interpretations about the nature of the sequence and its convergence properties.
There seems to be some confusion regarding the relationship between the sequence and a related series, as well as the fundamental properties of the sine function at integer multiples of π. This has led to questions about assumptions and definitions in the problem setup.
realism877
I need to find out if this function is convergent or divergent when finding the limit to infiniti.
nsin(npi)
How do I solve this? Do I use the squeeze theorem or lhospital rule?
Evaluate the function in n=0,1,2,3,... Do you see a pattern??
I want to know how to do this algebraically
If you follow my hint then you can do it algebraically.
It goes in increments of 180
What is [itex]n*\sin(n*\pi)[/itex] for n=1,2,3,4 ? What is the exact result??
nsin(npi)
This sereis 1→∞ Ʃnsin (n∏) is equal to 1→∞ Ʃ(-1)^n (n) which is divergent hence given sereis is DIVERGENT
What? Where did you get the sum from? The question was only about the sequence.
realism877, do you not know what [itex]sin(\pi)[/itex], [itex]sin(2\pi)[/itex], [itex]sin(3\pi)[/itex], ... are? Your statement "it goes in increments of 180" implies that you do not, "[itex]\pi[/itex] radians" is the same as "180 degrees" but you should not have to convert to degrees to get this nor should you have to use a calculator. If you have taken a trigonometry or pre-calculus course you should know those "by heart"!
