Electric field in a hollow cylinder
The problem involves determining the electric field magnitude in the region between the inner and outer radii of a thick hollow cylinder with a non-uniform volume charge density. The specific question pertains to the limits of integration when calculating the enclosed charge.
  • The original poster questions the limits of integration for finding the enclosed charge when applying Gauss' theorem, specifically whether to integrate from the inner radius to the outer radius or just to the variable radius.
Participants are exploring the application of Gauss' theorem and clarifying the integration limits. Some guidance has been provided regarding the appropriate limits for the integration based on the specified region of interest.
The discussion is constrained by the specific conditions of the problem, particularly the requirement to find the electric field in the region defined by Rin < r < Rout.
magnifik
An infinitely long thick hollow cylinder has inner radius Rin and outer radius Rout. It has a non-uniform volume charge density, ρ(r) = ρ0r/Rout where r is the distance from the cylinder axis. What is the electric field magnitude as a function of r, for Rin < r < Rout?
for this problem, when you find qinside, do you integrate from Rin to r or from Rin to Rout? I'm confused because i would have expected it to be the latter, but in the solutions they integrate from Rin to r. can someone please explain this?
also, if you try to find the e-field where r > Rout, do you integrate from r to Rout?
Solution is here (problem II):
http://www.physics.gatech.edu/~em92/Classes/Fall2011/2212GHJ/main/quiz_help/200908/q2s.pdf
Just use Gauss' theorem. The surface has radius r, and
q(inside) is whatever's inside!
since in the example in the document it asks for Rin < r < Rout.. why does it integrate from Rout to r??
It doesn't. It integrates from Rin to r.
but why not Rin to Rout?
Because ity asks for the field at Rin < r < Rout, not AT Rout.
