Finding quadratic maclaurin polynomial
The discussion centers on finding the quadratic Maclaurin polynomial for the function f(x) = x sin(x). The key conclusion is that the quadratic Maclaurin polynomial is the second-degree term, which is x^2, not a fourth-degree polynomial. The derivatives of f(x) were calculated up to the fifth order, but the first non-zero term at x=0 is indeed the second-degree term. Graphing both y = x sin(x) and y = x^2 reveals their similarity near the origin.
  • Understanding of Maclaurin series and Taylor series expansions
  • Knowledge of calculus, specifically differentiation
  • Familiarity with polynomial functions and their degrees
  • Ability to graph functions using tools like Desmos or graphing calculators
  • Study the derivation of Taylor series for various functions
  • Learn about higher-order derivatives and their applications in polynomial approximations
  • Explore the differences between Maclaurin and Taylor series
  • Practice graphing functions and their polynomial approximations to analyze behavior near critical points
Students studying calculus, particularly those focusing on series expansions and polynomial approximations, as well as educators teaching these concepts.
kiwifruit
the question asks to find the quadratic maclaurin polynomial for f(x)
Given f(x) = x sin(x)
i know that a maclaurin series is when a=0 in a taylor series.
i did the 1st-5th derivatives of f(x) and then used the formula for taylor polynomial and set a=0.
f'=sin(x) + x cos(x)
f''=2cos(x) -x sin(x)
f'''=-3sin(x) -xcos(x)
f''''=-4cos(x) +xsin(x)
f'''''=5sin(x) +xcos(x)
with the formula for taylor polynomial
Pn(x) = n
Ʃ [f^k (a) (x-a)^k] / k!
k=0
by setting a=0 i got Pn(x)=0+0+x^2 -0- (x^4)/6...however the answer seems to be P(x)=x^2
anyone able to explain to me how that is so?
i think i got it... is the quadratic maclaurin polynomial just the 4th order maclaurin polynomial??
No, the "quadratic" MacLaurin polynomial is NOT fourth degree. It is, as is any quadratic polynomial, second degree. You are correct that the function and first derivative are both 0 at x= 0 so the first non-zero coefficient is the second degree term. The "quadratic MacLaurin polynomial" for this function is just that second degree term, [itex]x^2[/itex].
Graph both y= x sin(x) and [itex]y=x^2[/itex] on the same coordinates. You should find that they remarkably similar close to the origin.
