Diffusion coefficient in diffusion equation and random walk ?
The discussion revolves around the concept of the diffusion coefficient as it appears in the diffusion equation and in the context of random walks. Participants explore whether the diffusion coefficients in these two scenarios are equivalent or if they differ, and if they do differ, what the relationship between them might be.
  • Xu questions whether the diffusion coefficients (D) in the diffusion equation (J=DdT/dx) and the random walk (tao^2=6Dt) are the same or different, and if they are different, what the relationship is.
  • xxh418 asserts that the values of D are the same under specific conditions: uniform, isotropic, and constant diffusivity; no correlation between jumps; no other driving force for flux; and dilute concentrations.
  • Xu seeks clarification on the term "dilute concentrations," noting that in random walks, diffusion could occur with a single atom, while the diffusion equation involves a concentration gradient, particularly in cases like lithium diffusion in silicon nanowires where concentrations may be relatively high.
  • A later reply explains that "dilute concentrations" refers to conditions where the activity coefficient of the diffusing species is nearly independent of concentration, indicating that diffusion is driven by gradients in chemical potential rather than concentration gradients.
Participants express differing views on the applicability of the concept of "dilute concentrations" and its implications for the equivalence of the diffusion coefficients in the two equations. The discussion remains unresolved regarding the specific conditions under which the coefficients can be considered the same.
Limitations include the dependence on specific assumptions about uniformity, isotropy, and the nature of the concentration gradients involved in diffusion processes.
xxh418
Hi all:
Now I have a question about the concept of diffusion coefficient in two cases: the diffusion equation (J=DdT/dx) and the random walk (tao^2=6Dt). My quesion is the two D in two equations are the same or different. If they are different, is there any relationship between them?
Best
Xu
Hi xxh418:
The value of D in the two equations is the same under the restrictions used to derive the equations: uniform, isotropic, and constant diffusivity; no correlation between jumps; no other driving force for flux; and dilute concentrations.
Hi Maple
Thank you for your reply. What does the "dilute concentrations" mean? In random walk, there could be only one atom to diffuse in the solute. For the diffusion equation, there will be a concentration gradient. For the mass(atom) diffusion in solid crystals, for example, the Li diffusion in Si nanowire, the concentration of Li could be relative high. In this case, how we judge if it is dilute concentration?
Regards
Xu
This detail arises from the fact that diffusion is driven by gradients in chemical potential, not by gradients in concentration. However, the difference is negligible for dilute concentrations. Specifically, "dilute" means that the activity coefficient of the diffusing species is (nearly) independent of concentration. For more details, see, for example, Baluffi et al.'s Kinetics of Materials or any good graduate text on diffusion.
  • · Replies 41 ·
11K
  • · Replies 30 ·
