Heat transferred during an infinitesimal quasi static process of an ideal gas
The heat transferred during an infinitesimal quasi-static process of an ideal gas is expressed as dQ = (Cv/nR)(VdP) + (Cp/nR)(PdV). In this equation, dQ represents the change in heat, Cv is the heat capacity at constant volume, Cp is the heat capacity at constant pressure, n is the number of moles, R is the ideal gas constant, V is the volume, P is the pressure, dV is the change in volume, and dP is the change in pressure. The relationship is derived from the fundamental equations dQ = Cv*dT + PdV and dQ = Cp*dT - VdP, where dT is the change in temperature.
  • Understanding of ideal gas laws and properties
  • Familiarity with heat capacities (Cv and Cp)
  • Knowledge of quasi-static processes in thermodynamics
  • Basic calculus for handling infinitesimal changes
  • Study the derivation of the first law of thermodynamics in relation to quasi-static processes
  • Learn about the implications of heat capacities (Cv and Cp) in different thermodynamic processes
  • Explore the concept of infinitesimal changes in thermodynamics
  • Investigate the application of the ideal gas law in real-world scenarios
Students and professionals in thermodynamics, mechanical engineers, and anyone studying the behavior of ideal gases during quasi-static processes.
jrklx250s
Show that the heat transferred during an infinitesimal quasi static process of an ideal gas can be written as
where dQ = change in heat
Cv= heat capacity while volume is constant
n= number of moles of gas
R= ideal gas constant
Cp= heat capacity while pressure is constant
V = volume, dV = change in volume
P= Pressure, dP = change in pressure
Alright so this I honestly had no idea how to start since this is a quasi-static process
We must use these equations
dQ= Cv*dT + PdV
dQ= Cp*dT - VdP
where dT is change in temperature since this is not adiabatic we cannot rule out temperature
Any suggestions where to go from here ?
dQ= Cv*dT + PdV
dQ= Cp*dT - VdP
Find dT by equating the equations for dQ.
ehild
11K
