Calculate Diprotic Acid Species Concentrations
  • Thread starter Thread starter jonnyupton
    Acid
The discussion revolves around calculating the concentrations of species in a diprotic acid solution, specifically relating pH to the concentration of undissociated acid species ([H2A]) and vice versa. Participants explore the mathematical relationships and equations necessary for modeling the dissociation process in an Excel framework, considering the complexities of multiple equilibria and the need for minimal assumptions.
  • Homework-related
  • One participant seeks to relate pH to the concentration of undissociated acid ([H2A]) and asks how to derive this from known values of [H+] and dissociation constants (Ka1, Ka2).
  • Another participant suggests that the stoichiometric relationship between [A2-] and [H+] is not straightforward and questions the assumption that [A2-] equals [H+]/2.
  • A participant expresses difficulty in finding useful relationships from existing resources and notes that multiple unknowns complicate the equations needed to solve the problem.
  • One participant provides initial equilibrium concentrations for the acid species and describes the context of a liquid-liquid extraction process, emphasizing the need to relate [H2A] to [H+] for plotting equilibrium curves.
  • Another participant questions the focus on [H2A] and suggests estimating total acid concentration from pH, while expressing doubt about the accuracy of pH measurements for determining acid concentrations.
  • A participant clarifies that [H2A] is crucial for relating total acid concentrations in both phases of the equilibrium mixture.
Participants express varying levels of understanding and approaches to the problem, with some uncertainty about the relationships between species concentrations and the implications of pH measurements. No consensus is reached on the best method to calculate [H2A] or the stoichiometric relationships involved.
Participants note that the relationships involve multiple unknowns, requiring several equations to solve. The discussion highlights the complexity of the dissociation process and the potential inaccuracies in using pH for concentration determination.
This discussion may be useful for students and professionals in chemistry and chemical engineering, particularly those working with acid-base equilibria and mathematical modeling of chemical processes.
jonnyupton
I would like to relate the pH of an aqueous phase diprotic acid solution to a value of the undissociated acid species concentration in the aqueous phase, and vice versa.
I have Ka1 and Ka2 values for the acid.
The overall dissociation equilibrium can be written:
Ka1*Ka2 = ([A2-]*([H+]^2))/[H2A]
The pH can be used to give a direct value for [H+], so my question is: from this how do I find the value of [H2A]?
Additionally, for a given value of [H2A], how do I calculate the value of [H+]?
This work is for the purpose of creating a mathematical model in Excel for the dissociation process. The pKa1 and pKa2 values of the acid are close together and I would like to try and avoid as many assumptions as possible, no matter how hard the maths becomes.
Is anyone able to help?
Chemistry news on Phys.org
I have previously found and read that webpage but cannot figure out how that helps in this case.
As far as I can work out I need to work out the stoichiometric relationship between the A2- and H+ ions.
Is is accurate simply to say that [A2-] is equal to [H+]/2 from the dissociation stoichiometry?
I am afraid that means you will be not able to solve your problem.
There is no stoichiometric relationship of this type. One of the equations on the page I linked to describes the relationship you are looking for - but it is far from simple stoichiometry.
No, it is not that simple.
Could you please then explain which relationship I can use to solve the problem?
I am a final year Chemical Engineering student with only my basic A-Level Chemistry to rely on here and I'm not finding that it's helping much in this case.
All the relationships described involve at least 2 unknowns and therefore require at least 2 equations to solve them.
Which of the equations listed will I have to substitute into which?
After reading your first post I was under impression you are looking for equation that will let you find concentration of any form of the acid as a function of pH ([H+])- and there are three such equations on the page. But now I am no longer sure I know what you are looking for. Please elaborate.
I have an initial aqueous phase concentration of diprotic acid H2A of 0.2 M.
pKa1 4.418
pKa2 5.412
pKa 9.830
Ka1 3.82E-05
Ka2 3.87E-06
Ka 1.48E-10
[ACID]aq = [H2A]aq + [HA-]aq + [A2-]
I have calculated the equilibrium concentrations of all species in the aqueous phase as:
[ACID]aq [H2A]aq [HA-]aq [A2-]aq [H+]aq
0.200 0.197 2.74E-03 3.86E-06 2.75E-03
However, these equilibrium concentrations are taken to be initial concentrations in a liquid-liquid extraction process.
Over time an equilibrium is established between a 2nd phase which then leaves overall equilibrium species concentrations in the aqueous phase: [H2A]aq, [HA-]aq, [A2-]aq and [H+]aq
In the model I am developing I am setting different [H2A]aq values at the overall equilbrium and need to relate these to a corresponding [H+] such that an equilibrium curve can be plotted between each phase.
In addition, experimentally, the only data I have available is pH (hence [H+]) of the aqueous phase at the overall equilibrium. I would therefore like to know how to use this data to calculate [H2A]aq such that [ACID]aq can then be calculated.
Does this clarify... or makes things worse!?
Why do you concentrate on H2A?
You can start estimating total acid concentration from the known pH - solve equation 9.14 for Ca. Then use equations 9.11 to 9.13 to calculate concentrations of different forms. But I doubt in accuracy of this approach - measuring pH is one of the least accurate methods of acid concentration determination.
[H2A]aq is the species concentration used to relate the total acid concentrations in both phases of the liquid-liquid equilibrium mixture which is what I am interested in. Only undissociated acid is transferred between the two phases in this case.
I will try as you suggest and see how well the model then predicts the system.
10K
