I need a good explanation of phase and magnitude spectra
The discussion centers on understanding phase and magnitude spectra in the context of periodic signals. It highlights how a periodic signal x(t) can be represented using harmonically related exponentials, with specific examples provided, such as 3*e^{j 2ω} and 2*e^{j 3ω}. The amplitude spectrum is defined by discrete values of frequency and amplitude, while the phase spectrum is represented by the phase coefficients of Fourier components, expressed as Aejφejωt. The distinction between amplitude and phase in Fourier series is clarified, emphasizing their roles in signal representation.
  • Understanding of periodic signals and their representation
  • Familiarity with Fourier series and Fourier transforms
  • Knowledge of complex numbers and their applications in signal processing
  • Basic grasp of amplitude and phase in the context of signal analysis
  • Study the properties of Fourier transforms and their applications in signal processing
  • Learn about the relationship between amplitude and phase in complex signals
  • Explore the concept of Fourier series and its application to real signals
  • Investigate the significance of phase spectra in analyzing signal behavior
This discussion is beneficial for signal processing engineers, electrical engineers, and students studying Fourier analysis and its applications in various fields such as communications and audio processing.
Jncik
I understand that having a periodic signal x(t) we can find a signal y(t) which uses harmonically related exponentials in order to construct the x(t) signal
each exponential has a frequency and magnitude, for example
[tex]3*e^{j 2 \omega}[/tex] has a frequency of [tex]\frac{2 \pi}{2 \omega} = \frac{pi}{\omega}[/tex]
and also a magnitude of 3
similarly [tex]2*e^{j 3 \omega}[/tex] has a frequency of [tex]\frac{2 \pi}{3 \omega}[/tex]
and a magnitude of 2
now if we plot the amplitude spectra of y(t) we will get discrete values where for the x coordinate we will be having the frequency, and for the y the amplitude on that frequency
so we will have a discrete value on the frequency(x) [tex]\frac{\pi}{\omega}[/tex] with an amplitude(y) of 3 and also a value for the frequency(x) [tex]\frac{2 \pi}{3 <br /> \omega}[/tex] with an amplitude of 2
I hope that I'm correct
now, the thing is that I don't understand the phase, what will the phase represent? for example suppose we have this graph
[PLAIN]http://img191.imageshack.us/img191/8259/unledpsg.png
what does the phase graph represent? what are these lines referring to? if you can please explain the x,y coordinates and what they mean
thanks in advance :)
The coefficients of Fourier components of a signal are complex numbers, having both magnitude and phase. So they look as Aeejωt. The amplitude spectrum shows A(ω) and the phase spectrum is φ(ω)
If you use real Fourier series instead of complex ones, the components are of the form Asin(ωt+φ). A is the amplitude and φ is the phase of the Fourier component.
ehild
