What was the first mineral formed in the universe?
  • Context: Undergrad
  • Thread starter Thread starter Whalstib
    Universe
The discussion revolves around identifying the first mineral formed in the universe, exploring various hypotheses related to mineral formation, elemental composition, and the conditions necessary for solidification. Participants engage with concepts from geology, chemistry, and astrophysics, considering both theoretical and historical perspectives.
  • One participant suggests that SiO2 might be considered the first mineral due to its stability and presence in meteorites.
  • Another participant proposes water as a candidate but acknowledges that it would only qualify as a mineral under solid conditions at or below 0°C.
  • A participant questions the timeline for the formation of minerals, noting that elements evolved from hydrogen and that stability at high temperatures and pressures could affect mineral formation.
  • Discussion includes the idea that after the Big Bang, elements like lithium and hydrogen were present, with lithium hydride potentially being the first mineral formed.
  • Diamonds are mentioned as a possibility, with references to their presence in red supergiants and nanodiamonds found on Earth.
  • One participant argues that the question of the first mineral is malformed, suggesting that early substances were gaseous and that solidification would depend on conditions allowing for clumping and conglomeration.
  • Another participant speculates that carbon could be a candidate for the first mineral.
Participants express multiple competing views regarding the identity of the first mineral, with no consensus reached. The discussion remains unresolved, with various hypotheses presented and debated.
Participants highlight the complexity of defining minerals based on temperature and pressure conditions, as well as the influence of elemental abundance and nucleosynthesis processes on mineral formation. There are unresolved assumptions regarding the timeline and conditions necessary for solid minerals to form.
This discussion may be of interest to students and enthusiasts in geology, chemistry, and astrophysics, particularly those curious about the origins of minerals and elemental formation in the universe.
Whalstib
Hi,
This is more complicated the more I consider all the variables.
Klein defines a mineral as:
“A mineral is a naturally occurring homogeneous solid with a definite (but generally not fixed) chemical composition and a highly ordered atomic arrangement. It is usually formed by inorganic processes.”
SiO2's are most common on Earth and seem to be so based on stability. Meteorites have species of SiO2 and I'm wondering if one of those is considered the first mineral forme din the universe.
What do you think?
W
Astronomy news on Phys.org
Water.
Water...hmmm?
Well it would have to be solid and one would have to determine the time line for 0°C to exist as water is not a mineral except under 0°C...right?
That's why I wondering about what elements tend to bond stable at higher T and P.
I'm a geology student and unsure about chemistry/physics at this level but aren't all elements assumed to have "evolved" from H? It would follow they would sort themselves based on the periodic table and heavier elements forming later. Electronegativity etc would play a roll.
At any rate you are saying T was at or below 0° C before any other minerals could form...High T & P silicates etc...? Higher P would make lower T more difficult to obtain right?
I'm unconvinced but plead ignorance as well. If you've a mind could you elaborate?
Thanks,
W
After the universe was created, all matter that existed at the time was approximately (By mass) 75% Hydrogen, 25% Helium, and a smattering of other others such as Lithium and Beryllium, about 10^-10 of a percent of the latter 2 though. Elements such as Silicon, Oxygen, Carbon, ETC were all created by nucleosynthesis inside the first stars. While it is true that the ratio of elements does tend to follow the periodic table, there are some significant differences due to the different methods of fusing elements together, stability of certain elements, and other effects. For example, Oxygen is ranked as the third most abundant element yet is the 8th element. See here: http://en.wikipedia.org/wiki/Abundance_of_the_chemical_elements
Almost certainly the first mineral would have been Lithium Hydride as the ingredients, Lithium and Hydrogen, were created in the Big Bang hundreds of thousands of years before the first stars and millions of years before the first supernovae, the real engines of nucleosynthesis.
Whalstib said:
Water...hmmm?
Uh. OK. I guess I assumed its solid state at a given temperature and pressure was one of the things you'd be least interested in.
Thing is, "solid" is an agglomerate property of a mass of atoms, not a property of atoms themselves. Almost anything in the early stages of the universe would have been gaseous until such time as it could cool enough and massive enough to begin to clump together under gravity.
So, by your strict definition even your SiO2 and Blibbler's HLi would not have been solid - let alone minerals - until they could clump into pebbles, rocks and planetesimals.
So, your question is malformed. It is more meaningfully: When the first substances were finally able to conglomerate into solids, what might those solid proto-rocks have been composed of?
Note that, by the time this happened, there were surely multiple substances floating in gaseous form available to form solids, which means there would have been no single "first".
i.e.:
first materials were formed that (when they eventually could reach a certain temp & pressure) would tend toward solids - there would have been myriad substances in this category
then the conditions arose for them to form all solids simultaneously.
Carbon I'm guessing
  • · Replies 49 ·
  • · Replies 35 ·
9K
