How to calculate flow rate and pressure in connected pressure vessels?
  • Thread starter Thread starter fjalla
    Flow Pressure
This discussion outlines a systematic approach to calculate flow rate and pressure in two connected pressure vessels containing gas at different initial pressures. The procedure involves breaking the problem into discrete time steps, where the flow rate is calculated assuming constant pressures during each step. The perfect gas law is applied to update the pressures in both vessels after accounting for the mass transfer, and the process is repeated until equilibrium is achieved. The compressibility factor 'Z' is also utilized when necessary to refine pressure calculations.
  • Understanding of the perfect gas law
  • Knowledge of compressibility factors, specifically the 'Z' factor
  • Familiarity with flow rate calculations in fluid dynamics
  • Basic principles of mass transfer between connected systems
  • Study the application of the perfect gas law in varying conditions
  • Research compressibility factors and their significance in gas calculations
  • Learn about numerical methods for solving differential equations in fluid dynamics
  • Explore advanced flow rate measurement techniques in connected vessels
Engineers, physicists, and anyone involved in the design or analysis of gas systems, particularly those working with pressure vessels and fluid dynamics.
fjalla
I have two pressure vessels containing gas at different initial pressure and connected by a pipe. I know the initial condition in both vessels and I have to calculate the flow rate and the pressure in the two vessels over time until equilibrium is reached. Do you have any suggestions?
Welcome to PF !
I would break the problem into time steps. Here is the basic procedure:
a) During the time step, assume the pressures in the two vessels are constant and figure out the flow rate.
b) Multiply the flow rate in Step 'a' by the timestep. This will be the quantity of gas that flowed during the time step.
c.1) Subtract the mass determined in Step 'b' from the higher pressure vessel.
c.2) Determine the new (lower) pressure in the higher pressure vessel with the perfect gas law. The pressure is lower since mass has left the vessel. Use the 'Z' compressibility factor if needed.
d.1) Add the mass determined in Step 'b' to the lower pressure vessel.
d.2) Determine the new (higher) pressure in the lower pressure vessel with the perfect gas law. The pressure is higher since mass has entered the vessel. Use the 'Z' compressibility factor if needed.
e) Go To Step 'a'. The difference in pressures is now lower and so will be the flow rate. Repeat until the two vessel pressures are equal. Add up all the time steps and this is the total time.
  • · Replies 38 ·
