Precalc project: positive values in an inequality
The problem involves determining the set of positive values of x that satisfy the inequality (1/x) - (1/(x-1)) > (1/(x-2)). The context is precalculus, focusing on inequalities and rational expressions.
  • Participants discuss various methods, including graphing the inequality and solving for x. Some express uncertainty about the relevance of their attempts and question the interpretation of the multiple-choice format.
There is ongoing exploration of the problem with multiple interpretations of the inequality and its solution format. Some participants suggest substituting values from the answer choices into the inequality as a potential approach, while others clarify the meaning of union in the context of set notation.
Participants note that the problem is presented as a multiple-choice question, which may influence their approach to finding a solution. There is also discussion about the implications of undefined values in the inequality at certain points.
hpdwnsn95
Determine the set of positive values of x that satisfy the following inequality:
a) (0, 1) union (2^1/2, 2) b) (0, 1/2) union (1, 2) c) (1/2, 1) union (2^1/2, 2(2^1/2))
d) (0, 2^1/2) union (3/2, 2) e) (1, 2^1/2) union (2, 2(2^1/2))
i'm not sure that there are any relevant equations, just started precalc a few weeks ago and I'm not sure how to solve the problem
I've tried graphing the equation and then tracing x to find y, but I haven't been able to find an answer that way. I've also tried solving for x which i get 1/2 > x for, but I'm not sure if that applies to this problem
The first step would be to combine the two fractions on the left side.
Is this actually a multiple choice question? Is that what the a) b) c) etc refer to ?
Remember that if this is a multiple choice question, you do not have to find the answer, you only have to identify which of the 5 offerings is the answer.
While not a great method of solving a problem, substituting the offerings into the original inequality may be the fastest way for you to solve this.
If you do not know or see a clever trick to use, then solving the problem using basic principles is the best way. In the sample problem, start by adding the additive inverse of the righthand member to both sides; then perform the arithmetic steps for the rational expressions. You have some rational expression related to zero. Now just focus on the numerator.
Given that x is positive, I would separate this problem into three parts:
x between 0 and 1: both x- 1 and x- 2 are negative.
x between 1 and 2: x- 1 is positive but x- 2 is negative
x greater than 2: both x- 1 and x- 2 are positive.
For each of those, multiply the entire inequality by x(x-1)(x-2).
yes it is
I would do that but I don't understand the answer format, i"ve never seen union answers before, can you (or anyone else) expain them?
Do you know what the definition of the union of two sets is?
i think union stands for and right? so it's like one set & one set
but I'm not sure how would plug either set into the problem because there's no y in the problem
One piece (interval) of the x-axis plus (as in union) another piece. --- Actually, all the numbers in one interval together with all the numbers in another interval together with ...
The first option
suggests it is true for any value between 0 and 1, as well as values between √2 and 2, but false for values between 1 and √2, and false for values above 2
it is clearly undefined for x = 0,1 or2 due to a fraction becoming 1/0
You could substitute 0.5 [1/2], and check it is true, 1.25 [5/4] and check it is false, 1.5 [3/2] and check it is true and 3 to check it is false.
Solving is better, but substitution could be your last resort.
