Relative Gravity: How Size Affects Force of Gravity
  • Context: High School
  • Thread starter Thread starter DB
    Gravity Relative
The discussion centers around the relationship between the size of a planet and the force of gravity experienced by an individual on that planet. Participants explore how gravity varies with different planetary sizes and clarify the concept of weight in relation to Earth.
  • One participant questions how a larger planet produces more gravity and seeks to understand the underlying mechanism.
  • Another participant explains that general relativity describes gravity in terms of the curvature of spacetime, influenced by energy and momentum, leading to curved paths for massive bodies.
  • It is noted that weight differences on various planets are relative to Earth's gravity, with mass remaining constant across different gravitational fields.
Participants generally agree that weight is relative to Earth and that mass does not change, but the discussion does not resolve the initial question about the mechanism by which larger size affects gravity.
The discussion does not delve into specific mathematical formulations or assumptions underlying general relativity, nor does it clarify the implications of different gravitational fields on weight measurement.
DB
What is the force that pushes your body down on a bigger planet making you weigh more? I know it's gravity, but how does more size produce more gravity exactly? And when people say you would weigh more or less on a different planet, they mean more or less relative to the Earth right?
Astronomy news on Phys.org
The current effective theory of gravity is general relativity, so the explanation is in terms of that. GR says that the curvature of spacetime geometry near a point is determined by the energy and momentum near that point. Zero curvature would be euclidean geometry and nonzero curvature is some kinds of noneuclidean geometry. "Straight lines" in a noneuclidean geometry are curves. So your heavy body is trying to move on a straight line but because the geometry is different it moves on a curved path in spacetime. A curved path in spacetime embodies an acceleration. So that's why.
And yes, the "heavier" or "lighter" on different planets is relative to Earth.
Right. Your mass is essentially constant, so as you move yourself (your mass) to different gravitational fields (e.g., different planets), the weight you measure (which is mass x gravity) differs accordingly.
Thanks guys.
  • · Replies 19 ·
  • · Replies 22 ·
