What is the temperature of a cooling bath made from solid CO2 and ethanol?
The temperature of a cooling bath created by mixing solid CO2 with ethanol is definitively -78.5°C. This temperature corresponds to the sublimation point of solid CO2, which transitions to gas at this temperature. Ethanol remains in a liquid state at -78.5°C, as its freezing point is -114.5°C. The cooling bath effectively utilizes the latent heat of sublimation from CO2 to maintain this low temperature.
  • Understanding of phase transitions, specifically sublimation and freezing points.
  • Knowledge of the properties of carbon dioxide (CO2) and ethanol, including their respective temperature thresholds.
  • Familiarity with laboratory cooling bath applications and their purposes.
  • Basic principles of thermodynamics related to latent heat.
  • Research the thermodynamic principles of sublimation and latent heat in detail.
  • Explore the phase diagrams of CO2 and ethanol to visualize their states at various temperatures.
  • Investigate alternative cooling bath methods using different substances and their temperature ranges.
  • Learn about laboratory safety protocols when handling cryogenic materials like solid CO2.
Chemistry students, laboratory technicians, and researchers involved in experimental setups requiring low-temperature environments will benefit from this discussion.
kottur
A cooling bath is prepared in a laboratory by mixing chunks of solid CO2 with ethanol. CO2(s) sublimes at -78.5°C to CO2(g). Ethanol freezes at -114.5°C and boils at +78.4°C. State the temperature of this cooling bath and describe what will be seen when it is prepared under ordinary laboratory conditions.
The answer is -78.5°C.
Not sure if there are any equations. Might just be a graph with a critical point or something like that.
First of all, the definition of a cooling bath is a bath that maintains a low temperature close to 0°C right? I suppose that the mixture of CO2 and ethanol is with solid CO2 (given) and liquid ethanol, so does the ethanol break up the CO2 or something? Anyway at -78.5°C ethanol is still liquid and CO2 is just in between solid and gaseous state. I don't understand how the answer is -78.5°C and I also would like to understand what happens in the cooling bath like the question states.
Thank you! :)
It is mostly about the latent heat - question assumes there is enough solid carbon dioxide used.
Mixture is prepared using ethanol at - most likely - room temperature, so it will be cooled down by subliming CO2. How far down can the temperature go?
  • · Replies 32 ·
10K
  • · Replies 19 ·
12K
16K
