New Reply
South Pole colder than the north pole. why ??????
Share Thread Thread Tools
Nov11-11, 02:47 PM   #1
Hello .. I have a question .. Why the South Pole colder than the north pole ???? (for the earth).
PhysOrg.com
PhysOrg
earth sciences news on PhysOrg.com
>> Oklahoma twister tracked path of 1999 tornado
>> Alaska volcano's ash prompts flight cancellations
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
Nov11-11, 02:52 PM   #2
Abundance and proximity of moisture (Artic Ocean) at the north one moderates temperature swings. South pole is deep inside a continental land mass.
Nov11-11, 02:56 PM   #3
It's land, not sea.
It's 3000 m above sealevel
Nov11-11, 02:59 PM   #4
Quote by willem2 View Post
It's land, not sea.
What do you mean .. Please explain
Nov11-11, 02:59 PM   #5
D H
Mentor
Quote by tasp77 View Post
And it is at a high elevation. The South Pole is about 2800 meters above sea level.
Nov11-11, 03:54 PM   #6
Height increases as less heat
Nov11-11, 05:28 PM   #7
Evo
Mentor
Quote by nafaa View Post
Yes, it is colder at higher altitudes.
Nov12-11, 10:10 AM   #8
rbj
also, the earth is at it's aphelion when the southern hemisphere is having its winter (like in June). so when we, in the north, have winter (like in December), the earth is closest to the sun in its orbit. i would think that this would contribute to making our winters more mild than the southern hemisphere's winters.
Nov12-11, 10:33 AM   #9
D H
Mentor
Quote by rbj View Post
also, the earth is at it's apogee when the southern hemisphere is having its winter (like in June). so when we, in the north, have winter (like in December), the earth is closest to the sun in its orbit. i would think that this would contribute to making our winters more mild than the southern hemisphere's winters.
Correction: The correct terms are aphelion/perihelion, rather than apogee/perigee. Apogee means "furthest from the Earth" and pertains to objects such as the Moon and artificial satellites that orbit the Earth. Aphelion means "furthest from the Sun" and pertains to planets such as the Earth that orbit the Sun.
That doesn't answer your question. You would think that the eccentricity of the Earth's orbit would make seasons in the southern hemisphere more severe than seasons in the northern hemisphere. The effect is quite small. The reason is that the southern hemisphere has only half as much land area as does the northern hemisphere. Water has a rather high specific heat compared to rock.
Nov12-11, 02:26 PM   #10
Is the South Pole is the highest area (for the sea level) on the surface of the planet???
Means the South Pole is higher than the summit of Mount Everest, therefore, at low temperature???
Nov12-11, 02:51 PM   #11
Evo
Mentor
A good starting point for you would be to learn how to use a world atlas. I'll start you off with the South Pole, then you can find the information on Mt Everest. It is so much better to learn how to use the proper resources.
http://www.worldatlas.com/webimage/countrys/an.htm
Nov13-11, 12:52 AM   #12
Antarctica is essentially a dome... Very cold from higher in the atrmosphere drops down and flows outwards toward the ocean, where a lack of nearby landmasses ensure the prevailing winds are circular around the base of the mound. Outside warmer influences are thus prevented from getting in... (incidentally, this may just have a slight consequence for global warming theorists!!!).
Nothing complicated in science... just observe, record and interpret!!!!!!!
pmarchant.
Nov13-11, 02:17 AM   #13
Recognitions:
Gold Membership Gold Member
Please observe (as stated previously) that the Arctic ice-cap is surrounded by and floating on a sea and that sea has a thermal mass that moderates the temperature up there. The Antarctic is surrounded by an ocean, but it is mostly ice-on-land, with relatively little shelf-ice. Yes, some pretty large chunks of ice have broken off Antarctic shelves over the past years, but that doesn't significantly diminish the mass of the Antarctic ice-cap. A very different set-up.
Nov13-11, 09:55 AM   #14
I found that the high summit of Everest 8848 m above sea level. The highest point in Antarctica point Vinson Massif at 16,066 feet (4897 m). This means that the summit of Mount Everest should be higher colder than the Antarctic because of the Mount Everest, the highest up from Antarctica. Increase in height leads to lower heat
Is this true???
Nov13-11, 10:06 AM   #15
D H
Mentor
That would be correct if all other factors were equal, but all other factors are not equal.
Nov13-11, 10:14 AM   #16
Quote by D H View Post
Indeed.
Mt. Everest is but a small place, surrounded by more temperate climes. Antarctica is ice sheet for about 1000 miles in every direction.
Mt. Everest is relatively near the equator where summer is quite warm. Summer near the poles is anemic at best.
etc.
Nov13-11, 10:27 AM   #17
Recognitions:
Homework Helper Homework Help
Yes, increase in height leads to lower temperature.
Beyond that the Antartic receives less incident sunlight.
And more of the sunlight received is reflected back by snow and ice.
New Reply
Thread Tools
Similar Threads for: South Pole colder than the north pole. why ??????
Thread Forum Replies
North pole and south pole of a magnet. General Physics 10
north and south pole in an electromagnet General Physics 11
North/South pole identifier Electrical Engineering 1
lhc at the north pole General Physics 6
Wire does a loop of wire create a norh pole and a south pole General Physics 2
