Long-winded finding of Limiting Reagent
  • Thread starter Thread starter Up_Creek
The discussion centers on determining the limiting reagent in a chemical reaction involving acetic anhydride (CH3C(O)-O-C(O)CH3) and salicylic acid (C7H6O3). The molar weights are calculated as 102.09 g/mol for acetic anhydride and 138.12 g/mol for salicylic acid. The limiting reagent is identified as salicylic acid, present in 0.011 mol compared to 0.53 mol of acetic anhydride. The theoretical yield of the product (C9H8O4) is calculated based on a 7.43% actual yield, resulting in approximately 0.145 grams of the final product.
  • Understanding of balanced chemical equations
  • Knowledge of molar mass calculations
  • Familiarity with percent yield concepts
  • Basic principles of stoichiometry
  • Calculate theoretical yield for various reactions
  • Explore the concept of limiting reagents in different chemical reactions
  • Learn about percent yield calculations in organic chemistry
  • Investigate the implications of yield on practical applications in chemistry
Chemistry students, laboratory technicians, and anyone involved in chemical synthesis and yield optimization will benefit from this discussion.
Up_Creek
Ok.
Balanced Equation
CH3C(O)-O-C(O)CH3(l) + C7H6O3(l) ---> C2H4O3 + C6H4(OCOCH3)CO2H
Trying to find limiting reagent here...
mWt CH3C(O)-)-C(O)CH3(l) = 102.09 g/mol
5.4/102.09 = 0.53 mol
mwt C7H6O3(l)= 138.12 g/mol
1.5g/138.12 = 0.011 mol
I have the actual percent yield (as per experiment) at 7.43% but I also need the theoretical yield.
Chemistry news on Phys.org
Practical yields are calculated on theoretical yields, which is assumed 100%. In your example, salicylic acid is the limiting reagent, since it is only present in 11 millimoles compared with 530 millimoles of acetic anhydride.
[tex]C_7H_6O_3[/tex] gives [tex]C_6H_4(OCOCH_3)CO_2H[/tex], so 102.09 g of the first compound will give [tex]C_9H_8O_4=180.16 g/mol[/tex]. If you isolated the product with about 7.5% yield, then your final product weighs about 0.145 grams, right?
