Charged particle motion in a uniform magnetic field
The discussion centers on the behavior of a charged particle moving in a uniform magnetic field, specifically regarding the effects of increasing the magnetic field strength. As the magnetic field strength increases, the Lorentz force acting on the particle also increases, resulting in a larger radial acceleration. However, the tangential velocity of the particle remains constant, leading to a decrease in the radius of its circular orbit. The key conclusions are that the magnetic field does not increase the kinetic energy of the particle, and no electric field is present in this scenario.
  • Understanding of Lorentz force and its implications on charged particles
  • Knowledge of circular motion and centripetal acceleration
  • Familiarity with magnetic fields and their effects on charged objects
  • Basic principles of kinetic energy in physics
  • Study the implications of the Lorentz force on charged particle dynamics
  • Explore the relationship between magnetic field strength and particle motion
  • Investigate the principles of centripetal acceleration in varying magnetic fields
  • Learn about the role of electric fields in charged particle motion
Physicists, engineering students, and anyone interested in electromagnetism and the dynamics of charged particles in magnetic fields.
chrisbaird
Consider that we have a macroscopic, electrically charged, point object tracing out a circular path in a uniform magnetic field in the usual way due to the Lorentz force. Now we very slowly raise the overall strength of the magnetic field (slow enough that on one orbit, the object sees the same field). Will the instantaneous speed of the object increase, or will its speed stay the same and its radius of orbit decrease? Consider everything is large enough and slow enough that we can ignore relativistic effects and the object does not radiate.
What do you think? Let me ask you two questions:
(1) Can the magnetic field ever increase the kinetic energy of the particle?
(2) Is there an electric field in the case you described?
Well, a larger magnetic field would exert a larger magnetic force on the particle, providing a larger acceleration. But the larger acceleration is in the radial direction of its circular motion, so the tangential velocity will remain unchanged, so the radius of orbit must decrease. On the other hand, in circular motion, the centripetal acceleration is proportional to the tangential velocity, so it would seem a higher acceleration would mean higher velocity.
  • · Replies 26 ·
