Entanglement & GR: Can We Measure Universe Info?
  • Context: Graduate
  • Thread starter Thread starter mjames
    Entanglement Gr
The discussion revolves around the implications of quantum entanglement in the context of general relativity (GR) and black holes. Participants explore whether entangled particles can remain so when one falls into a black hole or when they are separated by extreme cosmic expansion, and what this means for the information accessible to observers in light of GR's constraints.
  • Some participants propose that entangled particles can remain entangled even if one falls into a black hole or if they are separated by extreme expansion, questioning the implications for information access.
  • Others argue that while entanglement exists, local experiments cannot distinguish this non-local entanglement from local randomness.
  • A participant suggests that measurements on entangled particles do not imply causation between them, challenging the notion of "forbidden" information being transmitted.
  • Some participants express uncertainty about the definition of information, with differing views on whether the state of one particle can provide information about its entangled partner.
  • One participant asserts that mixing GR and quantum mechanics leads to inconsistencies, suggesting that entanglement cannot exist within a classical framework like GR.
  • Another participant mentions that experiments have shown correlations between measurements taken before light cones intersect, leading to discussions about non-locality and its implications.
  • There is a claim that a local observer does not have access to information about the state of a particle that is not within their light cone, despite the entanglement.
Participants generally do not reach consensus, as multiple competing views remain regarding the nature of entanglement, the implications of GR, and the definition of information in this context.
Limitations include the unresolved nature of how entanglement interacts with the event horizon of black holes and the implications of cosmic expansion on information transmission. The discussion also highlights the dependence on definitions of information and the challenges of integrating quantum mechanics with general relativity.
mjames
Let's say you have two entangled particles. Is it possible for one of them to fall into the event horizon of a black hole and the particles still be entangled? Or say the two particles are far apart and the universe undergoes extreme expansion (just after the Big Bang, say) such that they are still entangled but no longer in each other's light cones?
If this were so, does the entanglement mean you now have some information about part of the universe which GR says you can't? Also, how can you even tell if the particles are still entangled?
What "forbidden" information is going to be transmitted exactly? I think you will see there is none. Also, you should know that ordering of measurements on entangled particles is generally not meaningful to the outcomes. You cannot say that the one in the black hole "causes" the other one to take a value any more than you can say the reverse.
The particles are still entangled but there is no local experiment which distinguishes this non-local entanglement from local randomness.
In case of inflation one could do the following: create pairs of entangled particles, wait for inflation to start such that the light cones do no longer intersect, perform some local experiments and store the data. Now wait long enough such that the light cones do again intersect, exchange the data and compare the results. I think via such an experiment long after inflation you can detect entanglement prepared prior to inflation.
From Wikipedia: "When a measurement is made and it causes one member of such a pair to take on a definite value (e.g., clockwise spin), the other member of this entangled pair will at any subsequent time be found to have taken the complementary value (e.g., counterclockwise spin)."
So isn't the "forbidden" information which is transmitted, the spin value? If no information was transmitted, wouldn't it be just as likely that randomness could produce the same, noncomplementary, spin, as opposed to what I am calling the information transmittal which will invariably result in the complementary spin?
And isn't the measurement, say performed on particle A while particle B is not measured, the cause of the taking on of values?
My point wasn't that forbidden information was being transmitted. My understanding of these two situations is that you can't know anything about the state of the other side of a event horizon (whether you happen to be inside it or outside it), or anything that's not in your light cone.
But with the case of an entangled pair of particles separated in either of these two ways, you can know there is one particle in a state you know about by looking at the local entangled particle to which you have access. It doesn't matter whether or not you happened to look at the particles' state before they got separated. What does matter is that you can deduce the state of a particle which you can't directly observe by looking at its entangled opposite. What I'm wondering is if you've got a tiny bit of information that GR says you can't have.
By looking at one particle you can't decide if it belongs to an entangled pair or not (regardless where the partner particle may be)
It depends on your definition of information. No one owns the word.
I say that it is information, but others say it is not information because the measurement can't be used to send a signal. I would be happier if they were to say "electromagnetic information" or "signaling information" or some such.
If you are using GR (a classical theory) then there is not entanglement possible. If you are using QM (a non-geometrical theory) then there is not event horizon possible. You cannot mix both.
One of the basic requirements of a scientific model of nature is its internal consistency.
You do not need to go to such extremes. We have already done experiments on Earth where the two measurements are both started and completed before the light cones of the two locations intersect. We already know "if" information is going from one to the other it is going at a rate >1E6 times the speed of light.
This leads people to say "it" is non local. Not sure what is non local. Not sure what non local means. For myself I am still stuck back with Newton and Einstein for A to effect B, A must touch B. Fields are OK, A effects the field, the field propagates the impulse with finite speed (=< c), the field effects B.
Yes.
That's possible too.
If by "you" you mean "a local observer", then the answer is - no. The local observer does not have this information.
Experimentally, you can't. But physics is not only about experiments. For example, even without quantum mechanics, GR says that there is something beyond the horizon, and yet it says that you cannot measure it.
I understand that normally (without entanglement) when either of these cases happens and something disappears "over the horizon" you no longer have any idea of what happened to it. But if you are dealing with one-half of an entangled pair and you still have local access to the other half, why can't you tell the state of the particle over the horizon by looking at the local half? Isn't this possible with entangled pairs that are light years apart but not over the horizon? Why does this aspect of entanglement break down when one of the pair is over the horizon?
My point is that I am wondering if there is an inherent contradiction between QM and GR here. Nothing I know of in QM says you can't tell the state of one of a pair of entangled particles by looking just at the other one of the pair. There's nothing I know of in QM that says there's an exception to entanglement for something over the horizon (does QM even have a concept of "over the horizon"?). Yet as you say, GR says there's no way you can know anything about something over the horizon.
According to you GR rules, but isn't the argument behind QM just as strong?
QM and GR are irreconcilable in some respects, which is partly why the search is on for a theory that will somehow contain both of them or for a deeper theory that will supersede them. As for whether an entangled particle beyond the horizon would still have a property opposite to its twin here, or not, it seems like it would be a little difficult to find out.
But that's wrong. You do have a very good idea. Of course, you cannot measure it, but to "have an idea" is not about measuring. "To have an idea" is to have a theory, and the theory (general relativity) says very clearly what happens there.
But you can, provided that you trust your theory (general relativity and quantum mechanics).
Yes, it's possible.
It doesn't break down.
Here, there is no such contradiction. Perhaps somewhere else (e.g., there is a black-hole information paradox for the case when the black hole EVAPORATES), but definitely not here.
And you are right.
Please read carefully what I say. I never said you cannot KNOW it. You can, by theory. I said you cannot MEASURE it.
According to me, they both rule and there is no contradiction.
mjames said:
My point wasn't that forbidden information was being transmitted. My understanding of these two situations is that you can't know anything about the state of the other side of a event horizon (whether you happen to be inside it or outside it), or anything that's not in your light cone...
tom.stoer and demystifier have made several comments that are good and worthy of re-reading. I would like to add a couple of comments.
Obviously there is "something" which indicates the presence of a black hole in the first place, that being distortion of spacetime. So is that the kind of "information" which you think is forbidden too? My point is that your initial premise is inconsistent with the facts.
Similarly if you look at entangled quantum objects per QM, there is no contradiction with interacting with a BH. You would have 1 of 2 possible situations: a) The photon entering the BH (say Alice) has her wave function collapse; or b) it doesn't. Either of which are indistinguishable anyway, according to any test you can do on her entangled partner (Bob)! Which is the normal situation anyway with entanglement.
Is there anything in existing theory (GR or QM) that would lead you to believe that either a) or b) is a possibility that cannot occur? Because we already know that c is not a boundary for entanglement, why should a BH's event horizon be any different?
In concept, you could even consider Bob and the BH to be an entangled system.
  • · Replies 58 ·
  • · Replies 18 ·
  • · Replies 19 ·
