Mathematica: Plot a vector NOT against the component number
The discussion focuses on using Mathematica to plot a list object against a custom scale derived from a function of the component number. The user successfully implemented a solution by defining a function, myf[n_] = n^2, to create a new scale and then transposing the results for plotting. The final code snippet provided, ListPlot[myresult, PlotJoined -> True, AxesOrigin -> 0], effectively visualizes the data as intended. This method allows for greater flexibility in plotting beyond the default component numbering.
  • Familiarity with Mathematica programming language
  • Understanding of list manipulation in Mathematica
  • Basic knowledge of plotting functions in Mathematica
  • Concept of function mapping in programming
  • Explore advanced plotting techniques in Mathematica
  • Learn about custom tick marks and scales in ListPlot
  • Investigate function mapping and transformation in Mathematica
  • Study data visualization best practices for effective representation
Mathematica users, data analysts, and anyone interested in advanced data visualization techniques using custom scales in plots.
faradayslaw
Hi,
I wish to listplot a list object against a scale that is NOT the component number of the vector, but is actually a well defined function of the component number, and I am lost how to do this?
changing "Ticks" didn't help, or I did it wrong, so I am wondering if anyone knows how to do this.
Thanks
Construct your substitute for the "component number" and transpose to put it in position
Example:
mylist = {1, 2, 7, 4};
myf[n_] = n^2;
myscale = Map[myf, Range[Length[mylist]]];
myresult = Transpose[{myscale, mylist}];
worked well, thanks
