Solving Physics Problems: Coefficient of Friction and Force Calculation Tips
  • Thread starter Thread starter nippongo2001
    Physics
The discussion revolves around a physics problem involving a sled on an inclined plane, focusing on the coefficients of static and kinetic friction. The original poster seeks assistance in determining the forces required to initiate and maintain motion up the incline.
  • Participants discuss the relationship between static friction and the forces acting on the sled, questioning how to calculate the minimum force needed to overcome static friction and the force required for constant velocity. Some participants explore the implications of net force and the balance of forces in the context of the problem.
There is an ongoing exploration of the mathematical processes involved in solving the problem. Some participants have provided insights into the forces at play, while the original poster continues to seek clarification on specific calculations and the concept of net force.
The original poster expresses confusion regarding the mathematical setup and the presence of multiple variables in their calculations. There is a focus on understanding the conditions under which the sled begins to move and the forces involved in maintaining motion.
nippongo2001
When you're given the coefficients of both kinetic and static friction, what can you determine from this information, and how do you go about finding it?
For example, I was given a problem in physics that says the following:
A loaded sled weighing 70N rests on a plane inclined at 20 degrees to the horizontal. Between the sled and the plane, the coefficient of static friction is 0.26, and the coefficient of kinetic friction is 0.11.
a. What's the minimum magnitude of force that will start the sled moving up the plane?
b. What's the value of force required to move the block up the plane at constant velocity?
If there's any way that you can help with any aspect of this problem, I would be permanently in your debt! Thank you!
Remember:
STATIC friction has the magnitude it needs to have in order to keep the object at rest, up to a MAXIMAL value, given in terms of the static friction coefficient multiplied with the normal force.
Hence, the MINIMUM force required to get the sled moving, is to apply a force equal to the maximum value static friction can have.
For your b) question, the applied force must exactly balance the kinetic force of friction in order to keep the sled's acceleration zero (i.e, its velocity constant).
To start something moving, you need to overcome static friction.
Once the block is moving, you have to consider kinetic friction.
Thank you very much! Your help is indeed appreciated!
However, I am still having difficulty with the actual mathematical process in part A. Is the net force zero? If not, I still come up with two variables at the end. For part A:
In the x direction:
Force_net = F_applied - F_friction - F_parallel
F_net = F_a - (70cos20 x .26) - 70Sin20
F_net = F_a - 17.1028 - 23.9414
Thank you!
Yes.
In the x direction:
F_applied = F_friction + F_parallel
  • · Replies 16 ·
