Calculating O2 Weight Needed for 100g NH3 Reaction | Step-by-Step Guide
  • Thread starter Thread starter median27
    Assignment
The discussion focuses on calculating the weight of O2 required to react with 100 grams of NH3 in the reaction NH3 + O2 → NO + H2O. To solve this, the equation must first be balanced, followed by determining the number of moles in 100 grams of ammonia. Using stoichiometry, the equivalent moles of oxygen can then be calculated, and finally, the weight of oxygen needed can be derived using the formula moles = grams/molar mass. This structured approach ensures accurate results in stoichiometric calculations.
  • Understanding of chemical equations and balancing reactions
  • Knowledge of stoichiometry and mole calculations
  • Familiarity with the concept of molar mass
  • Basic skills in algebra for calculations
  • Learn how to balance chemical equations effectively
  • Study stoichiometry principles in chemical reactions
  • Explore molar mass calculations for various compounds
  • Practice solving stoichiometric problems involving gases
Chemistry students, educators, and anyone involved in chemical reaction calculations will benefit from this discussion, particularly those focusing on stoichiometry and reaction balancing.
median27
What weight of O2 in grams will be required to react with exactly 100 grams of NH3 ascending to the eq.
NH3+O2--->NO+H2O
I think none.
I don't have any attempt on this problem because my brother only ask for my assistance regarding this assignment and he too doesn't know how to start this problem- the fact that it is under their next lesson.
I just want to help my brother, so I risk to post it here. I hope somebody would help me and will explain how the solution goes so that i can relay it to him. Thanks :)
NH3+O2--->NO+H2O
I think none.
First of all the equation needs to be balanced ( there are more hydrogens on the left than the right). Then you need to calculate the number of moles 100g of ammonia contains. Then using the stoichiometry of the reaction use that to calculate the equivilant number of moles of oxygen required to react with that many moles of ammonia. Using moles=grams/mr you can calculate the weight of oxygen needed. Post back in this thread if you get stuck
thanks
thanks
thanks for your speedy reply! :D
11K
9K
9K
9K
