How Do You Calculate the Equilibrium Angle of a Square Coil in a Magnetic Field?
  • Thread starter Thread starter ldzcableguy
    Physics
The equilibrium angle of a square coil in a magnetic field can be calculated using the torque equation τ = IABsin(θ). For a coil with a mass of 0.100 kg, side length of 0.100 m, carrying a current of 3.40 A in a magnetic field of 0.0100 T, the angle θ is determined to be 0 degrees, indicating the coil remains vertical. The torque acting on the coil at equilibrium is calculated to be 1.70 x 10^-5 Nm, derived from the magnetic force acting on the coil.
  • Understanding of torque and its calculation in physics.
  • Familiarity with the concepts of magnetic fields and forces.
  • Knowledge of current, area, and their roles in magnetic interactions.
  • Ability to apply trigonometric functions, specifically sine and arcsine, in problem-solving.
  • Study the derivation and application of the torque equation τ = IABsin(θ).
  • Learn about the principles of magnetic forces on current-carrying conductors.
  • Explore the relationship between magnetic field strength and coil orientation.
  • Investigate the implications of equilibrium in mechanical systems involving magnetic fields.
Physics students, electrical engineers, and anyone interested in understanding the dynamics of coils in magnetic fields will benefit from this discussion.
ldzcableguy
The problem says:
A long piece of wire with a mass of .100 kg and a total length of 4.00m is used to make a square coil with a side of 0.100 m. The coil is hinged along a horizontal side, carries a 3.40-A current, and is placed in a vertical magnetic field with a magnitude of 0.0100 T. (a) Determine the angle that the plane of the coil makes with the vertical when the coil is in equilibrium. (b) Find the torque acting on the coil due to the magnetic force at equilibrium.
I am having trouble solving for the angle that the coil makes with the vertical...
Any help is greatly appreciated!
Can someone please help me?
I know that the equation T = BINAcos(theta) has to do with it and i can solve the torque to be .0034 Nm without the cos(theta) from the angle that the plane makes with the vertical but I have absolutely no idea how to solve for theta from the information that is given in the problem.
I also tried to solve for theta using F = BILsin(theta) using the mass to calculate the force by setting it equal to the weight which is mg then plugging in B, I and L but when I tried to use arcsin to solve for theta the number that I got was out of the domain of sin.
What I had was
wt = mg
wt = (.100kg)(9.81 m/s/s)
wt = .981 N
F = .981 N
F = BILsin(theta)
.981 N = (.0100T)(3.40A)(4.00m)sin(theta)
then I got:
sin(theta) = 7.213 and obviously this number is out of the domain of sin so I can't take the arcsin of it...
can someone please tell me what I did wrong or point me in a more correct direction because i am 100% stumped..
Sure, I'd be happy to help you with this physics problem! Let's break it down step by step.
First, let's define some variables:
m = mass of the wire (0.100 kg)
L = total length of the wire (4.00 m)
a = side length of the square coil (0.100 m)
I = current through the coil (3.40 A)
B = magnitude of the magnetic field (0.0100 T)
θ = angle between the plane of the coil and the vertical
(a) To determine the angle θ, we can use the equation for torque:
τ = IABsinθ
where τ is the torque, I is the current, A is the area of the coil (a^2), and B is the magnetic field.
We know the torque is zero when the coil is in equilibrium, so we can set τ = 0 and solve for θ:
0 = IABsinθ
0 = (3.40 A)(0.100 m)^2(0.0100 T)sinθ
sinθ = 0
θ = 0 or 180 degrees
Since we know the coil is hinged along a horizontal side, the angle θ cannot be 180 degrees (or else the coil would fall straight down). Therefore, the angle θ must be 0 degrees.
(b) Now, let's find the torque acting on the coil due to the magnetic force. The torque is given by the equation:
τ = r x F
where r is the position vector from the hinge to the center of the coil (in this case, r = a/2), and F is the magnetic force.
We can find the magnetic force using the equation:
F = IABsinθ
where I is the current, A is the area of the coil, B is the magnetic field, and θ is the angle between the current and the magnetic field.
Plugging in our values, we get:
F = (3.40 A)(0.100 m)^2(0.0100 T)sin(0)
F = 3.40 x 10^-4 N
Now, we can plug this into our torque equation:
τ = (0.050 m)(3.40 x 10^-4 N)
τ = 1.70 x 10^-5 Nm
So, the torque acting on the coil is 1.
