Understanding PDE Classification: Parabolic Equations and Quadratic Forms
  • Context: Graduate
  • Thread starter Thread starter S. Moger
    Classification Pde
The discussion revolves around the classification of a specific partial differential equation (PDE) as parabolic, focusing on the interpretation of quadratic forms and the reduction to canonical form. It includes theoretical exploration and mathematical reasoning related to PDE classification and transformations.
  • One participant presents a PDE and calculates the discriminant \(B^2 - AC = 0\) to argue that it is parabolic, questioning the interpretation of the number of squares in the quadratic form.
  • Another participant counters that the classification as parabolic is due to the ability to complete the square, providing a mathematical derivation to support this view.
  • A subsequent post discusses the implications of the condition \(C = \frac{B^2}{A}\) and how it affects the counting of squares in the quadratic form, suggesting that this condition leads to a single square.
  • Further, a participant outlines a method for reducing the PDE to canonical form through a change of variables, detailing the transformations and the resulting expressions for the coefficients in the new variables.
  • There is a query regarding the necessity of computing lower order terms when applying the chain rule in the transformation process, indicating uncertainty about the completeness of the reduction.
Participants express differing views on the interpretation of the number of squares in the quadratic form and the conditions for classifying the PDE as parabolic. The discussion remains unresolved regarding the implications of these interpretations and the completeness of the reduction process.
The discussion includes assumptions about the definitions of parabolic PDEs and the conditions under which the quadratic form is analyzed. There are unresolved steps in the transformation process, particularly concerning the computation of lower order terms.
S. Moger
Ok, so I got this equation:
[itex]y^2 \frac{∂^2 u}{∂x^2} + 2xy \frac{∂^2 u}{∂x∂y} + x^2 \frac{∂^2 u}{∂y^2} = 0[/itex]
[itex]A = y^2[/itex]
[itex]B = xy[/itex]
[itex]C = x^2[/itex]
Now I want to see what type it is, so I compute [itex]B^2 - A C = 0[/itex] which by definition is parabolic. However, according to an earlier statement in my book a parabolic PDE is one that has a quadratic form (at some point) that consists of fewer than n squares, not necessarily all of the same sign. n signifies the space we're in (that would be n=2). However, to me it seems like there are two squares in the equation, so it can't be parabolic?
Are they "reducing" it by writing [itex](y \frac{∂u}{∂x} + x \frac{∂u}{∂y} )^2 = 0[/itex] and saying it contains less than n squares after dropping the square?
No, that's not the reason The quadratic [itex]Ax^2+ 2Bxy+ Cx^2[/itex], with [itex]B^2- AC= 0[/itex] is "parabolic" Completing the square, [itex]A(x^2+ (2B/A)xy+ (B^2/A^2)y^2)- (B^2/A)y^2+ Cy^2[/itex][itex]= A(x- (B/A)y)^2- (B^2- 4AC)y^2/A= A(x- (B/A)x)^2[/itex], a "perfect square". That's the reason.
Doing what I think you do I get this:
[itex]A (x^2 + 2 \frac{B}{A} xy + \frac{C}{A}y^2)=[/itex]
[itex]A ((x + \frac{B}{A} y)^2 - \frac{B^2}{A^2}y^2 + \frac{C}{A}y^2)[/itex]
Using [itex]C=\frac{B^2}{A}[/itex] (i.e. parabolic)
[itex]A (x + \frac{B}{A} y)^2 - \frac{B^2}{A^2}y^2 + \frac{B^2}{A^2}y^2)=[/itex]
[itex]A (x + \frac{B}{A} y)^2[/itex]
This counts as one square (?), while a [itex]C \neq \frac{B^2}{A}[/itex] would generate an additional [itex]y^2[/itex] term?
Now when I know the type, how do I reduce this one to canonical form?
The strategy seems to be to make a change of variables to make most high order terms vanish.
[itex]\xi = \xi(x,y)[/itex]
[itex]\eta = \eta(x,y)[/itex]
By the chain rule:
[itex]u_x = u_\xi \xi_x + u_\eta \eta_x[/itex]
[itex]u_y = u_\xi \xi_y + u_\eta \eta_y[/itex]
Then it is applied again, so I get expressions for [itex]u_{xx}, u_{xy}, u_{yy}[/itex]. I reorder them and get
[itex]A^* \frac{∂^2 u}{∂ \xi ^2} + 2 B^* \frac{∂^2 u}{∂ \xi ∂ \eta} + C^* \frac{∂^2 u}{∂ \eta^2} + F^* = 0[/itex] with [itex]F^*[/itex] containing lower order elements.
where
[itex]A^* = A \xi_x \xi_x + 2B \xi_x \xi_y + C \xi_y \xi_y[/itex]
[itex]C^* = A \eta_x \eta_x + 2B \eta_x \eta_y + C \eta_y \eta_y[/itex]
[itex]B^* = A \xi_x \eta_x + B (\xi_x \eta_y + \xi_y \eta_x) + C \xi_y \eta_y[/itex]
I want [itex]A^* = 0[/itex], so I solve that and get
[itex]A( \xi_x + \frac{B}{A} \xi_y)^2 = 0[/itex]
i.e.
[itex]A \xi_x + B \xi_y = 0[/itex]
[itex]y^2 \xi_x + xy \xi_y = 0[/itex]
[itex]ydy = xdx[/itex]
[itex]y^2 - x^2 = \gamma = \xi[/itex]
Then I have to choose [itex]\eta[/itex] with respect to the Jacobian (it mustn't vanish), so I pick [itex]\eta=x^2[/itex] .
[itex]B^*[/itex] disappears as well here, which leaves [itex]C^*[/itex]
I'm left with
[itex]\frac{∂^2 u}{∂\eta^2} = - F^* / C^*[/itex]
Is this correct?
However, I still need to determine the contents of [itex]F^*[/itex], will I have to compute lower order terms each time I do the chain rule to get [itex]u_{xx}[/itex] [itex]u_{xy}[/itex] and [itex]u_{yy}[/itex]?
  • · Replies 36 ·
