New Reply
Number of interference fringes visible in the central diffraction peak
Share Thread Thread Tools
Nov24-11, 08:19 PM   #1
How many interference fringes are visible in the central diffraction peak if the ratio of slit separation to slit width is 3.125?
2. Relevant equations
d*sin(θ) = m*λ for interference maxima with slit separation d, maxima are at m = 0, 1, 2, 3 ...
a*sin(θ) = m*λ for diffraction minima with slit width a, minima are at m = 1, 2, 3 ...
3. The attempt at a solution
md = m for diffraction minima
ma = m for interference maxima
ma/md = 3.125
d*sin(θ) = md*λ
a*sin(θ) = ma*λ
-> d/a = (md/ma)*λ
When md = 1, ma = 3.125, so the central diffraction peak contains the 3rd order interference maxima. This means that there are 3 interference maxima on the right of the central interference fringe, and 3 on the left, giving a total of 7.
My instructor gave a formula to calculate the number of interference fringes visible in the central diffraction peak: 2(d/a) - 1
Using this, I get 2(3.125) - 1 = 5.25, or after rounding, 5 peaks. What am I missing?
Also, this formula allows for an even number of interference fringes in the central peak (consider d/a = 2.5, 2(2.5 - 1) = 4), is that possible?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Nov26-11, 07:35 AM   #2
Does anyone have any insight into this problem? I still haven't figured it out. Also, is it possible to have an even number of interference fringes in a central diffraction peak?
Nov26-11, 08:42 AM   #3
I think it is safe to assume that angles are small and therefore it is safe to assume
that Sin∅ = ∅
For the interference maxima the angular separation is therefore λ/d
The width of the central diffraction max is λ/a
Can you take it from there?
Also I think this gives the n=3 interference max at the min of the diffraction pattern so the interference max will not be observed. Therefor 2 each side of the central max (n=0 max)
Nov26-11, 08:44 AM   #4
I have that, I would just like to verify if my working and answer is correct.
And, if I could find out if it is possible for there to be an even number of interference fringes in a central diffraction peak.
Nov26-11, 10:42 AM   #5
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
Look at these patterns.http://www.sciencephoto.com/media/157199/enlarge
The width of the slits is 25 μm, and their separation is 75 μm in the upper pattern and 58 nm in the bottom one.
If the last interference maximum coincides with a diffraction minimum, you can not see it. That is seen in the upper picture when d/a=3: 5 maxima are seen. In your case, the 3rd maximum is inside the first diffraction maximum, so it is visible, although faint. You will see 7 maxima. In the bottom pattern, d/a =2.3. The second maxima are inside the main diffraction maximum, so you see 5 maxima again.
The number of maxima is integer. You need to take the integer part of d/a. The number of maxima is 2 int(d/a)+1, if d/a is not integer. In case it is an integer, the last interference maximum coincides with the diffraction maximum, and the number of maxima is 2int(d/a)-1.
There is no such thing that 2and a half maxima. If d/a=2.5, 2 maxima are seen on both sides (as int 2.5=2) and one in the middle, so 5 altogether.
ehild
Nov26-11, 10:44 AM   #6
Great, thank you for clarifying. That was very helpful.
Nov26-11, 12:59 PM   #7
Recognitions:
The pleasure was mine
ehild
New Reply
Thread Tools
Similar Threads for: Number of interference fringes visible in the central diffraction peak
Thread Forum Replies
Probelm with fringes/interference Advanced Physics Homework 0
Destructive interference and fringes Introductory Physics Homework 7
interference fringes Introductory Physics Homework 0
Light: Fringes and Interference Introductory Physics Homework 9
Interference Fringes General Physics 16
