What is the angle for perfect light blockage through a polarizer?
  • Thread starter Thread starter Cade
    Light Polarizer
The discussion focuses on the application of Malus' Law to determine the angles for light blockage through polarizers. For complete light blockage, the second polarizer must be oriented at 123 degrees relative to the horizontal axis, calculated by adding 90 degrees to the initial 33-degree angle. To achieve one-third light transmission, the final angle should be 87.7 degrees, derived from the equation I/I0 = cos(θ)², where θ is the difference in angles between the two polarizers. Clarification is sought regarding the correct interpretation of angle differences in the context of the problem.
  • Understanding of Malus' Law in optics
  • Basic knowledge of polarizers and light polarization
  • Familiarity with trigonometric functions, specifically arccosine
  • Ability to perform angle calculations in physics contexts
  • Study the implications of Malus' Law in different light conditions
  • Explore the behavior of light through multiple polarizers
  • Learn about the applications of polarizers in optical devices
  • Investigate the mathematical derivation of angle relationships in polarizer setups
Students studying optics, physics educators, and anyone interested in the practical applications of polarizers in light manipulation.
Cade
Unpolarized light passes through a polarizer oriented at 33 degrees from the horizontal axis.
1) At what angle (relative to the horizontal axis) would you place a polarizer so that no light passes through it?
2) At what angle (relative to the horizontal axis) would you place a polarizer so that only a third of the light from the
Malus' law
I/I0 = cos(θ)[itex]^{2}[/itex]
1) Light into the second polarizer is polarized at an angle of 33 degrees. No light will pass through the second polarizer if the difference in angles is 90°, so the second polarizer should be at an angle of 90° + 33° = 123°.
2)
[itex]\frac{1}{3}= cos(θ)^{2}[/itex] where θ is the difference in angles between the two polarizers.
[itex]θ difference = arccos(\sqrt{\frac{1}{3}})[/itex]
[itex]θ_{final} - θ{_initial} = arccos(\sqrt{\frac{1}{3}})[/itex]
[itex]θ_{final} - 33° = arccos(\sqrt{\frac{1}{3}})[/itex]
θ = 54.7° + 33° = 87.7° from the horizontal axis
But my instructor says that the left-hand side of the equation is [itex]θ_{final} - θ{_initial}[/itex], which results in θ = 54.7° - 33°, so I'm confused now... have I done these two correctly?
This is a physics problem, not math so I am moving it.
I'm sorry, I must have been looking at the wrong section when I posted it.
  • · Replies 25 ·
